FPR shimmin & clean DONE
Originally Posted by 2 stroke man
ya, i got my fpr shimmed. it was a booger to get that spring back in straight. screen was good. what would happen if that spring didnt seat against the triangular piece good?
Actually, the spring slides into and against the BB so they are all housed inside that triangular piece. The problem that raises it's ugly little head is that the spring slides off of that little "Tit" on the Inside of the cap and can put a kink in the spring further restricting the springs compression.
What kind of pressure did you end up with?
Rog
Originally Posted by kawa
S Stroke:
Rog
Rog
idk what pressure i got. aint checked it yet. what would be better than tearing up a tire gauge to check it?
Originally Posted by plowhand
A liguid filled 100 psi fuel pressure gauge with a short hose (the liguid and hose isolate some of the vibration and pulsing).
Originally Posted by 2strokeman
how much $$$ and where to get it?
-Robb
2 stroke, maybe. You don't want to go over 80 psi. much over that and the FPR cannot handle it all of the time and it comes apart.
StrokeThis, FPR shim = uses a BB to shim the spring in the Fuel Pressure Regulator that regulates the fuel pressure, thus raising your fuel pressure. Check this site: http://pages.prodigy.net/stevebaz/_i...az/index3.html
There are also several other sites about this (some with pictures). Do a search on here for FPR +shim.
