South Carolina Chapter Join Chapter, Leader: SC_Hoaty
George gets a new engine.
Old 04-22-2008, 04:44 PM
STGFordCrazy04's Avatar
STGFordCrazy04
STGFordCrazy04 is offline
Before
After
Specs
460 .030 .010 off deck 10.5:1 Comp balanced and blueprinted
Ported polished and port matched Trick Flow aluminum heads w/ stainless CJ valves
Comp cams Pro Mag roller rockers
3/8" pushrods with guide plates
Custom ground Lunati Voodoo Cam
Recurved distributor
Weiland Stealth intake port matched to heads and casting flash removed from runners
1" carb spacer 750 Holley (looking for a 850 replacement)
L&L 1 3/4 primary 3" collector headers
2 1/2" pipes with 2" H pipe and dual Flowmaster super 40s
some 500* rattle can paint
Should make a tick over 500hp and right at 600tq
Ive put my 545 on hold for now. Im waiting to buy pistons after I decide just how far Im going with it. The original plan was naturally aspirated with forged pistons in the 10:1 range but before its all said and done there could be 1 big turbo or 2 small turbos in the works. The sky and my wallet is the limit.
Old 04-22-2008, 05:03 PM
TheWiz427's Avatar
TheWiz427
TheWiz427 is offline
Sweet! I'll bet George will like his new heart. Although you better do something about those tires, Might i suggest some BFG AT's.
I hope you have a fat wallet.
Old 04-22-2008, 05:26 PM
STGFordCrazy04
HAHA. Without starting a offroad forum style debate... there will be no BFG ATs on this truck ever.
I put those tires on there so the cherry picker could reach the engine and lift it over the radiator support. It was too tall with my swampers.
Here it is with the bigger tires on it.
The 545 will be super expensive to build the way I want it even if I go the NA route. The turbo deal is more or less a brain fart because I really dont want to swap over to EFI and its waaaay too much trouble to tune a blow through carb. Id also have to go to an aftermarket block and billet crank. The upside would be 1000+ streetable HP.
Old 04-22-2008, 06:42 PM
5 Star Tuning's Avatar
5 Star Tuning
5 Star Tuning is offline
Former Vendor
Trouble to tune EFI ........Nice engine Kris....
Old 04-22-2008, 06:45 PM
TheWiz427's Avatar
TheWiz427
I know just kidding. If i wasn't doing the highway thing i have something like those on Meanie but for now the BFG's are good enough.
Are you intending to put the 545 in George when you do build it?
Old 04-23-2008, 11:57 AM
STGFordCrazy04
No....trouble to tune a carb for blow through. EFI is simple to setup for a turbo but I just dont want it on George. Dont ask me why because I dont have a good reason.
Harry,
The yoke is on its way to you.
Yeah the 545 will one day be in George. I have to build the truck up in phases. So far Im on phase 3 of 300.
Old 04-23-2008, 12:11 PM
TheWiz427's Avatar
TheWiz427
Harry,
Thanks.
You sound like me and the 54.
Old 04-24-2008, 09:09 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Haaa... once again, I'm about as dumb as a headless screw when it comes to the depths of carb engines...
Looks sweet tho!!...
Old 04-24-2008, 09:17 PM
STGFordCrazy04
Thanks Rich.
Carb'd engines make sense to me. I wont even change the spark plugs in my 04 2-fiddy.
Yall need to help me find a 850cfm carb and some leaf springs. Ive saved up some $$ and Im motivated for a change.
Check out the door panels I started building tonight.
http://i253.photobucket.com/albums/h...rpanels014.jpg
Honest opinions please
Old 04-25-2008, 06:39 AM
TheWiz427's Avatar
TheWiz427
Looks good but shouldn't you of used PT since George likes mud so much?
BTW I'm picking up a 77 long bed in Asheville Tuesday that will likely be parted out so if ya need something let me know.
Old 04-25-2008, 12:31 PM
STGFordCrazy04
Wiz,
treated? come on now Im not that bad.
Im going to stain and put a few coats of poly on it. They should last a little while.
Old 04-25-2008, 01:18 PM
TheWiz427's Avatar
TheWiz427
LoL, The poly will do the trick!
What year is George? Need parts?
alpha/omega
Offroad & 4x4
295
05-15-2014 09:36 PM
alpha/omega
Offroad & 4x4
365
10-14-2013 02:13 PM
alpha/omega
Offroad & 4x4
73
09-23-2012 10:17 AM
STGFordCrazy04
07-25-2008 10:57 AM
STGFordCrazy04
19
06-20-2008 08:26 AM
Quick Reply: George gets a new engine.
