Pushrod length
Old Apr 5, 2008 | 09:34 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Pushrod length
I just got a buttload of parts from ScottyJ at RHP and I need some final info.
Block decked .010 with Trick Flow streets and Comp Cams Pro Mag rollers what length pushrods do I need? 8.600?
Any recommendations on Brand?
Old Apr 5, 2008 | 10:13 PM
STGFordCrazy04
You know...
It might help if I gave a few more specs.
D1 block 460
.041 head gasket thickness
Head face has not been milled.
1.7 ratio Comp Cams Pro Mag rockers
This engine will be used as an occasional driver and for mud drags.
Old Apr 5, 2008 | 11:49 PM
mwvdub's Avatar
mwvdub
not sure about the length but Manton makes a real nice pushrod
Old Apr 6, 2008 | 09:37 AM
fordsrgrt's Avatar
fordsrgrt
try this for making your own adjustable pushrod.Simply take an old push rod and cut it about 1 to 1.5 inches from the end. Use a 1/4"-20 tap to cut threads into the open ends, and then screw in a short piece of 1/4-in. threaded rod. Use some nuts to lock the rod in position. Now you've got a adjustable tool that you can use to properly calculate and order the exact length pushrod.or you can buy one for about $20 or so from jegs or ask scotty
Old Apr 6, 2008 | 10:07 AM
STGFordCrazy04
Yeah.... I read how to do that last night. Ill probably make one to check things out.
I need to place an order with Jegs to get some little stuff for the build and I wanted to get it all one time.
Scotty said 8.600 would probably be the right size but like he and everyone else is saying I need to check on MY ENGINE. So thats what Ill do and place a second order with Jegs.
Thanks for the help guys.
Old Apr 6, 2008 | 10:34 AM
fasthauler's Avatar
fasthauler
Go to http://www.mantonpushrods.com] and download their catalogue. It has a wealth of information on pushrod specs, materials and how to order the proper length. This is the way I went on mine and they did a great job.
Old Apr 8, 2008 | 09:04 PM
kjett's Avatar
kjett
Originally Posted by STGFordCrazy04
You know...
Sheesh ya noob!!!! Ya think you coulda given a little more info to begin with.....
Just messing with ya there Kris.
Old Apr 9, 2008 | 01:33 AM
STGFordCrazy04
Thanks Karl. Nothings better than some good ol' newb bashing.
Old Apr 10, 2008 | 01:11 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
What cam are you running? Specs?
Thanks. I'm still undecided on a cam for my build.
Old Apr 10, 2008 | 06:22 AM
STGFordCrazy04
227/233 @.050 .552/.564 lift on 110 lsa
its a custom grind from Scotty at RHP (reincarnation-automotive.com) Great guy and great products. Id recommend him to anyone and will deffinately buy from him again. Hes that good.
Old Jun 15, 2008 | 01:17 PM
jef 429's Avatar
jef 429
pushrods length
This is a nice link to read for instalation for the size of pushrods
and rocker arm.
I think the information is there.
Setting Pushrods Length, Quick and Easy- Car Craft Magazine
Old Jun 15, 2008 | 01:23 PM
STGFordCrazy04
thanks for the link newb.
welcome to FTE!
Old Jun 16, 2008 | 05:49 AM
kjett's Avatar
kjett
That's right on time, as I'll be needing to get my push rod lengths later this week!
Old Jun 16, 2008 | 11:21 AM
STGFordCrazy04
just shove some 3/8s rebar cut with a hacksaw in the holes. You'll be fine.
Old Jun 16, 2008 | 12:37 PM
kjett's Avatar
kjett
I was thinking of that, but figured the re-bar would be too heavy and got too looking at twisting some bailing wire to about a 3/8's diameter just to keep it light and strong.......
