compression ratio for 70 429
Old 12-22-2001, 11:20 AM
schweg2's Avatar
schweg2
schweg2 is offline
Post compression ratio for 70 429
I have 13cc dished Sealed Power pistons (part#413np) with 75.8cc
combustion chambers and need to know what the compression ratio would be. The motor is a 1970 429. Thanks for any info!
Old 12-22-2001, 11:37 AM
Ford79's Avatar
Ford79
Ford79 is offline
Should be somewhere around 9.5:1 to 9.8:1.
Old 12-24-2001, 12:50 PM
schweg2's Avatar
schweg2
schweg2 is offline
[updated:LAST EDITED ON 24-Dec-01 AT 01:52 PM (EST)]>I have 13cc dished Sealed Power pistons (part#413np) with
>75.8cc
>info!
Old 12-24-2001, 12:53 PM
schweg2's Avatar
schweg2
schweg2 is offline
Does anybody else have any ideas?
Old 12-28-2001, 08:59 AM
dmoc1's Avatar
dmoc1
dmoc1 is offline
There is a lot of discussion on the compression ratio in the forum. If you do a search you can pick them up. Also, several websites have compression ratio calculators. Just do a search using those as key words. Some include deck height and gasket thickness, others are simple. Here is one.
http://www.musclecars.net/KnowledgeBase/MotorMath/compression.html
Hope it helps.
Dennis
55F100 w/429:-X12
Old 12-28-2001, 01:01 PM
390fe's Avatar
390fe
390fe is offline
Blown 331
12-24-2009 04:57 PM
IsoGrifo
10-16-2009 06:37 PM
1972 Ford Thunderbird 429 V8
12-19-2008 05:42 PM
Superdave
07-12-2003 01:21 AM
74crwcb429hibPS4spd
01-07-2003 01:28 PM
Quick Reply: compression ratio for 70 429
