General Diesel Discussion
6.0 Block Heater
Old 11-10-2013, 06:18 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Originally Posted by run6.0run
I hear that Josh,,, I've done many spurts where I would only shut off the truck to change the oil.
When it's -15f and you're working on construction equipment you leave the truck running.
Basically work 20-30 minutes, jump in truck to warm up, work 20=30 minutes hop in the truck and warm up.
I always heard the scares about wetstacking etc, and maybe I experienced that to an extent as after idling for several hours and driving off the engine ran like butt for a mile or 2 as it cleared out.
I always meant to install upfitters for the high idle mod, but my truck never had it.
Josh
  #92
Old 12-16-2013, 04:24 PM
dougie-Doo's Avatar
dougie-Doo
dougie-Doo is offline
Heater cord
Iv'e been having issues with my heater cord. When it gets wet it pops my GFI were I pug it in. Do I need to replace the cord or whats going on here. Its a 2007 F250 with the 6.0 in it. Any body got any ideas here.
  #93
Old 12-16-2013, 08:44 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
try spraying both the end on the truck and the extension cord with wd-40 if it still does it you probably need new cord ends. you can just put a new end on the old cord.
  #94
Old 12-16-2013, 10:22 PM
donjamer's Avatar
donjamer
donjamer is offline
I would try another extension cord before hacking the ends of the heater cord..
Also try replacing the GFI outlet.. They can go bad also
Cheaper to replace those before the heater cord
  #95
Old 12-21-2013, 08:38 PM
Deadeye2009's Avatar
Deadeye2009
Deadeye2009 is offline
Thanks for the help on this issue
After buying a 2006 F250 super duty with a 6.0 I was a little clueless about a lot of this stuff since it is my first diesel. I had the same problem. Got cold on me a couple times recently and had to jump start. I went on ebay and bought a cord for about $25. I plug it in on a timer so the heater turns on about 3 hours before i leave in the morning. It turns these cold Illinois winter temps to where the truck feels like it is starting in 60 degree weather. Thanks for all the information on this topic guys !!!
  #96
Old 12-08-2015, 12:22 AM
mboost26's Avatar
mboost26
mboost26 is offline
Overheating and no interior heat in cold weather...
I have an 03 6.0 that I have been having an issue with when cold out. I live in Colorado and it gets well under 0 here it has not got that cold lately but my truck has been overheating on cold mornings as well as my interior heat not working... I just put a new block heater in it and trying it out tonight plus I got the anti gel stuff in it as of tonight... anyone got any ideas why my truck is doing that? Seems that it helps pouring hot water in my coolant resivour... but interior heat still won't work after stopping the overheating problem... any help would be appreciated!
  #97
Old 12-08-2015, 11:13 AM
nitrogen's Avatar
nitrogen
nitrogen is offline
Are you using any antifreeze in the coolant? It should have enough to be safe for -25 or 30 F
  #98
Old 12-08-2015, 11:47 AM
mboost26's Avatar
mboost26
mboost26 is offline
Yeah I use a 50/50 mix but I do know I have a tiny slow leak somewhere have no been able to find it yet but when it overheats it blows all it's fluid out then I gotta refill it with hot water and antifreeze before it will cool down and run normal... I don't get why my interior heat quits on me sometimes makes no sense to me...
  #99
Old 12-08-2015, 11:59 AM
nitrogen's Avatar
nitrogen
nitrogen is offline
I'm going to guess bad water pump. The impeller can slip intermittently. No circulation = no heater. Sudden overheating shortly after startup sounds like pump again
  #100
Old 12-08-2015, 12:25 PM
mboost26's Avatar
mboost26
mboost26 is offline
OK awesome thank you! Now that you mention water pump I am going to have to agree. It makes sense to me. Thank you again!!!
  #101
Old 01-02-2016, 01:26 PM
Ira Dickens's Avatar
Ira Dickens
Ira Dickens is offline
trying to find the electric plug for my 06 6.0 block heater
I have fount a plug becide the right tow hook but it is a 3 pin flat plug is that my engine heater and if so can I change that plug to a standard house 110 outlet or do I need somthing else
  #102
Old 01-02-2016, 02:47 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
The ford cord had a join plug in the middle like that i think . Trace it back and see where it goes.
  #103
Old 01-02-2016, 02:51 PM
Bullitt390's Avatar
Bullitt390
That was the breakaway in case someone drove off with the extension cord still attached.
Josh
  #104
Old 01-06-2016, 06:42 AM
usmc2018's Avatar
usmc2018
usmc2018 is offline
I have a 2005 F-250 6.0 and im wondering, upon startup only on cold mornings, does anyone else have a problem blowing white smoke? This only happens the first time I startup every morning and only if its rather cold outside (40 and below).
  #105
Old 01-06-2016, 06:50 AM
Bullitt390's Avatar
Bullitt390
The same smoke every internal combustion engine does when it's frickin' cold out?
Josh
Quick Reply: 6.0 Block Heater
