What is wrong with this 7.3 PSD?
<TABLE><TBODY><TR><TD vAlign=top width="100%">My buddies kid brother drove their work truck into a pond. It is a 95 PSD, reg cab, short bed. They dried it out, and changed all filters and fluids, but it has a problem now. The truck will not accelerate. Anyone know what it could be?
</TD></TR></TBODY></TABLE>
Originally Posted by MADVAN
Try and flushout the trans connectors.
Also remove the throttle assembly. Do the same.
Flush out with electrical contact cleaner.
On a wag i would say the idle val switch has water in it and causing a failsafe lockout. (motor only idles).
Bill
Bill
On your "gas pedal" aka TPS when you press on the gas there is a button that should pop out as you press the pedal, this button tells the truck (no matter what voltage is coming from the TPS) that the truck should be at idle rpm. ensure this button pops out when you press the gas pedal, if it does, the water may be causing the connection to remain, or the TPS to not send voltage. Good luck. I would try running a blow dryer on the electrical part of the TPS. Also be ready to turn the truck off if the idle validation switch releases but the TPS but the TPS is sending max voltage because it is still wet, could concievably cause run away engine RPM (small chance but you never know)
I'm trying to help my buddy find these parts, but we cannot find anything under Accelerator Pedal Position Sensor, or Idle Validation Switch. Does anyone know what their part numbers are? No one at Autozone or Napa knew what they were. One guy at Autozone said someone was in looking for the same thing a month ago, but he had never heard of it. I know we know what we are talking about, but I cannot find them.
-Iasrap
-Iasrap
on
http://catalog.powerstrokeshop.com/p...&subcat2=86776
this is one of the cheapest places to get it. Also check ebay cause they do go cheaper on there as well. Also check junk yards.
