help w/ batteries
Originally Posted by star
Need to replace the two batteries on a 02 F350 Lariat w/a 7.3..do theres batteries have 650 cranking amps or 750?? thanks...
--> Motorcraft BXT65-750 is rated 750CCA and 935CA
--> Interstate MTP-65 is rated 850CCA and 1000CA
on
Batts
Got mine from NAPA - 850CCA + warranty. Be careful though - find a place that turns over a lot of batteries or you may get stuck w/ old ones that won't last long. (Check the mfg date codes - find ones <90 days old if you can) Also try to get two batteries w/ the same lot & date codes so they'll be fairly well matched.
DG
DG
Blue72forZach
16
08-15-2014 10:15 AM
fordinmudd
03-13-2010 07:16 AM
mountaineer27
24
12-17-2009 11:39 PM
gingerbreadmaniac
07-12-2002 03:13 PM
