-12* start
-12* start
I'm posting this because...Why not, It's what we do on here.
I didn't plug my truck in last night on purpose because I wanted to test starting using the LED. It is -12* F out right now.
I cycled the GP's twice for 1.5 min each, that is when the LED went out. Total of 3 mins of GP's being on, she started like it was plugged in...I'm not kidding, fired right up no sputtering. This is a much better starting results than I have had previously. Tons of white smoke though..but it is sucking in -12* air.
Just proves if your system is up to snuff, you should have no worries.
Stanco GP relay, 5w40 syn, new batteries, everything clean, LED GP indicator, factory starter (200500 miles on it).
I never plug mine in either.......I don't have the extra glow plug LED like you do, but I just cycle it a couple times. No problems........I have noticed a MAJOR difference in the ease of starting since I added Rotella 5w-40 synthetic though! I had 15w-40 Rotella before. It always started...but did some pretty bad "chugging" for 6-10 seconds before smoothing out. I think I'll add an LED glow plug light to my pillar once I get my gauges next week
The LED is just connected to the glow plug relay (GPR) and mounted somewhere in the dash/gauge area. That way it lights whenever the glow plug relay is powered...the Wait to Start (WTS) light is not in anyway connected to the GPR. Read this for more info.
Originally Posted by Kwikkordead
And your testimony is one reason that I don't ever bother to plug in my truck.
Originally Posted by jtharvey
While I agree with you that our trucks don't need to be plugged in, I do believe that it's easier on the engine when you do plug it in. I know the block heater heats only the coolant, but part of that heat has to transfer to the oil, and the warmer oil will flow easier making the engine achieve full lube sooner.
