7.3 Cavitation Pin Holes
sounds to me like the engine sat for some time in the past and you have some pitting from a cylinder that sat still. You cant see cavitaion damage from looking down the cylinder. you seem to be convinced that your engine is a grenade ready to go off... Unless you know for sure that the PO neglected the coolant SCA's your block is fine. The cavitation problem was on the left bank valley side of the block about 2 inches down the bore. cavitation can happen in any cylinder but the trend was for it to happen in 2 or 4 Each side of the block's cooling is seperate from the other side. you can check for pin holes with a bare block with some work making block off plates for the coolant holes on the front of the block and some rubber for a temporary head gasket use the hole in the side of the block to introduce water pressure. If water comes out pin holes you have cavitaion. If you don't want to go through this much work to check your block? you need to buy another block you feel better about.
you can go to autozone and rent a radiator pressure tester. go ahead and put the pressure to 13psi and watch it leak down. try to crank the engine over once the pressure has dropped. if your engine wont spin, like its locked up then you have cavitation issues, if it spins and you get more water in your oil then its your oil cooler.
My radiator level has remained pretty consistent, but I guess it doesn't take much water to contaminate the oil. Any help would be appreciated.
idiguy90
21
08-05-2015 08:37 AM
fedx95
Ford Truck Parts for Sale
02-17-2015 07:08 PM
Rentaro
89
07-08-2013 01:08 AM
