460 mods MORE POWER!!!!!!!!!!!!!!!!
Old 01-10-2008, 12:40 PM
bansheeduner's Avatar
bansheeduner
bansheeduner is offline
Talking 460 mods MORE POWER!!!!!!!!!!!!!!!!
i have a 97 f250 and i already have a cat back exaust modified air box i want more power and better milage and to remove my speed limiter any ideas would be helpful but i am getting my banks headers soon so i got that covered i want intakes tuners programmers cams heads any power secrerts for this truck and if you have site links and prices that would be great
Old 01-11-2008, 04:09 AM
65f100_352's Avatar
65f100_352
65f100_352 is offline
What do you want, horsepower or torque? For horsepower, go with after market heads intake, insanely huge cam, more compression, more cubic inches, and while your at it a blower, nitrous, run it on alcohol, maybe a shot of nitromethane, and top it all off with a quad turbo setup.
Old 01-11-2008, 10:14 AM
bansheeduner
power torque mileage and driveabilty and towing
Old 01-12-2008, 01:35 PM
solidrunner's Avatar
solidrunner
solidrunner is offline
Put a cam in it, it will make a huge difference. I just got a cam form comp for my 460 and I can see the difference just by looking at the lobes of the stock one and the new one.
Old 01-12-2008, 09:58 PM
Big_Man_Brad's Avatar
Big_Man_Brad
Big_Man_Brad is offline
ok so how much work is involved in putting a different cam in one of theses bad boys???And how much more do you get????like 10 hours???Have to be very skilled???? ect......................
Old 01-13-2008, 08:37 AM
my88beast's Avatar
my88beast
my88beast is offline
http://www.performanceunlimited.com/...g/results.html
that should help. seems like a great place for info. everyone bookmark it. easy, cheap, and they show the results.
Old 01-13-2008, 06:03 PM
65f100_352's Avatar
65f100_352
I haven't really tore into a 429/460, but it should be similar. Have to take off the intake, rocker arms, push rods, lifters, radiator, water pump, timing chain cover, timing chain and then the cam, and then reverse the process. It would take close to all day if nothing went wrong...
Id go with a comp 268. It gives you all the low end you want, more top end to 5500rpm, a real nice lope, and still get OK gas mileage, providing you keep your foot out of it.
Old 01-14-2008, 10:49 AM
bansheeduner
are high flow cats worth it on these trucks
Old 01-17-2008, 06:19 PM
stngh8r's Avatar
stngh8r
stngh8r is offline
Wink
Yeah, high flow will help. Mine is really high flow
Old 01-18-2008, 10:24 AM
bansheeduner
i just want more power its a 460 big block wheres the power my f 150 when it was stock could keep up with my truck what gives are there any mods to really wake this motor up
Old 01-18-2008, 08:29 PM
my88beast's Avatar
my88beast
not 100% sure but i would think a set of scj heads would wake that sucker up. dont know if they would work with the whole efi crap, but them are worth a bunch of power. someone around here should know. a hotter cam would help. but deff check this site out. http://www.performanceunlimited.com/...g/results.html
they did exactly what you want. power, acceleration, and mileage. at least check it out. the amount of acceleration that they unleased was amazing. the only thing you might want to watch for is the inspection stuff. obd II and sniffers. otherwise, some of the stuff on that site is worth good power/mileage and is relatively cheap and quick to do. really, most stuff is the same as would be with a stang, just with the 460. you might want to check out a stang forum or like summit racing with stang parts. it would be an easier way to get ideas and then implement or ask about them. always best to find out stuff first, then work them out. hope any of this helps.
Old 01-23-2008, 10:12 AM
bansheeduner
how much are heads
Old 08-16-2011, 11:03 PM
Vork's Avatar
Vork
Vork is offline
Before you dump so much money into it try a few simple mechanic tricks. If your truck is equipt with a smog pump, eliminate it using a smaller belt, block of the egr, and eliminate the hoses going to the smog pump. I did that on my 94 350 and on take off i can break lose the 35s no problem. and a throttle body spacer off a newer super duty with a v-10 will fit on a 7.5 with minor modification.
Old 08-17-2011, 07:22 AM
KrautBurner's Avatar
KrautBurner
KrautBurner is offline
N
Nitrous
100 shot should be fine Nitrous Outlet » Online Catalog » EFI Dry Nitrous Systems » Ford Systems
(that's what I have in my Daily Driver)
Old 08-17-2011, 02:46 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
This is a 3yr old thread
Quick Reply: 460 mods MORE POWER!!!!!!!!!!!!!!!!
