Headlight Bulb for '04
Guys have any of you changed a bulb on your 2004? I went into Napa today and I guess there is 2 different types of bulbs out there for the F-150. I didn't get a chance to take it apart yet to check which one it is. They sure don't look as easy to change as on the old trucks. Anyways one is an oval fitting with 4 prongs and the other is circular. My truck is an FX4 if that matters but, if anyone knows off the top of there head I appreciate the info. Thanks
You need type 9008 the housing comes out very easy. Just don't start unscrewing the wrong bolts or you will make the headlight out of adjustment.Head light bulbs should always be replaced in pairs due to different light intensity factors. Its cheaper to get two 9008 bulbs for 19.99 then paying the 12.99 for the single bulb.
