1991 F250 4x4 balljoints, need labor cost, time, and how much disassembly ?
on a 1991 F250 4x4 that i am trying to quote balljoint replacement labor on for someone i need to find out some things
i need to knwo what design of front end these have
are they CV shaft?
or not ?
coil spring ?
lower and upper control arms ?
radius arms ?
do you have to remove the knuckles completely as well as pull the CV shafts or do you leave the CV shafts on the front axle and pull the knuckles off them only ?
are the balljoints part of the arms or knuckles, or are they all removeable in 91 ?
are they all pressed in ?
no ball joint rivets or bolts ?
pics ?
how muvch time does the book say this takes ? around 6 hours ?
labor cost ?
what size ids the axle nut socket i will need and what type ? i have a few around but no clue if i have the one i would need for this truck
thanks for anything!
happy new year
are they CV shaft?
or not ?
coil spring ?
radius arms ?
pics ?
labor cost ?
happy new year
If i remember i will check the book tonight and see how much time/hrs it calls for. I have one of the ford shop manuels at home. i would assume it to be a decent amount of hours. those are the TTB axles on them not the mono beam so its alil more time consuming. lug nuts i think are 1 1/16th".
By the questions you're asking I can see you've never even been close to the front axle on this truck.
Leaf sprung, TTB axle. No CV axles. You remove the caliper, hubs, spindle nuts, bearings, spindle, and knuckle. The ball joints are pressed into the knuckle. You need a ball joint press to remove and install.
Since you're asking such basic questions, I have to wonder how you know the ball joints need replacing?
oh its not my truck
thats why i was wanting to know about time and labor
and no i havent worked on a later years front axle like this
nope
i thought these were IFS front
how can they not be CV shaft ?
what attaches the balljoints to the arms ?
must be bolts or rivets then if they are pressed into the knuckles
i need more info
thanks!
nope
i need more info
thanks!
the book calls for 6 hours. but from what i read you've never done anything like this before so if i were you id pickup a service manual and figure in a couple extra hours. Your gona need the special socket for disassembling the hub also. if your going through all of that you should probly replace the wheel bearings also and do all of the cv joints on the axles. also dont forget to regrease the hub assembly. brakes. there is alot there that you should do all at the same time. can get pretty pricy on parts. if your gona do all that go and get prices for all the parts and then you can figure that part and then just figure what your time is worth for a weekend.
good luck. its pretty easy stuff, but can just be a hassle sometimes. i have it down pretty good now and can do it in bout 3-4hrs.
there not a ifs suspension there a Twin Traction beam. its basicically the same as the chevy dana 44 as far as taking apart the hub assemblies. and the ball joints for that matter. If it were me i wouldnt do it for less than 200.00 plus parts. if you dont have the hub socket alot of parts stores will rent you the tool.
ok you guys have me all wrong here
wow
i have a weaver 9,000lb vehicle lift,
i have a huge garage two story even
overhead electric remote control engine hoist on rolelrs on huge steel I beams that also roll on more I beams perpendicular to them
i have a balljoint press
tall standing pneumatically, and manually, controlled tranny jacks
i have everything except possibly the exact socket i need for the spindle nut,
but im sure i have one somewhere either here at the building or at the garage
i jut need to know a few details
how the balljoints attach to the arms
and i cant understand what type of suspension or shafts a 91 would have
i can only imagine A arms and cv shafts
91 has regulr old style hubs ?
i thought they did away with those in 88 or 89 ?
the owner wants new balljoints on
i have to do a 99 or 2000 somthing ranger next
balljoints shot on it as well, my sisters dads truck
i have done billions of balljoints over ther years but not commonly ford truck ones
and the last one was years ago
and never has been a 90s or later one
now do you understand me ?
i didnt presume that i would have to explain myself so much just to find out a couple or three things
hmm
so complicated trying to get specific answers from anyone it seems
:O
i dont know what TTB is
i am not a later model ford person ok, i have never gotten into them, and im not muh interested in it unless i have to- for example on this upcoming repair job, and our 97 f150 4x4 as well -in which also needs balljoints, and the trans leak repair- and so on
i dont get with these later ones like some of you guys apparently do(here we go with assumptions/presumptions again haha)
and its not that i dont think i can do the job,
for i know that i am perfectly capable!
if you saw how i live and what i do every day of my life then you would have no doubt about it
vehicles and repairs and so on are my life, period,
i simply just wanted to find out what i could ahead of time to save myself extra surprises
maybe no one is willing to understand this process/concept... interesting..
if ppl dont want to explain a couple things then fine its not the end of the world for me, i will survive
i could be asking for too much here
i appreciate it though!
sometimes vehicles and repairs and researching and ppl really get to be to a point where i like to call it a huge PITA and would like say heck with it all and quit,
but life can be this way often
yes i need a vacation haha
from life maybe
thanks!
have a good year!
wow
hmm
:O
from life maybe
thanks!
have a good year!
Just remember that when someone asks if a Ford truck has CV axles and IFS, we all assume that you are pretty new to wrenching. More often than not, this is a pretty sound assumption.
This link will help you out: http://ford.off-road.com/ford/articl....jsp?id=198389
But it's for a Bronco/F-150. The TTB axle is the same, just leaf sprung in your case. You can't really explain how a TTB (twin traction beam) axle works. You really need to see it, but for purposes of ball joint replacement, you can treat it as a regular solid axle. There aren't that many differences as far as the job you're doing.
The TTB is not a solid axle and it's nothing like an IFS. It's a unique design and there are some pretty important differences. Once you look at it (or find a 4x4 Ford from 1980 to 1996) it will be pretty obvious what you need to do.
The link should explain it, but the ball joints are pressed into the knuckle. The threaded studs fit through machined holes in the end of the TTB arm. Once you see it it will become obvious how it fits together.
lol that was great!!! as i am not a ford guy myself but currently have 4 ford trucks in my garage now! sorry for not having all the specific info but it is a rather simple thing with the ball joints they are the same as the chevy's ! In fact the sockets for the fords are the same ones for the chevys & dodges. Any how hope you get that vacation soon. i myself get frustrated on here sometimes trin to get simple answers to simple questions too.
Justins311
1999 to 2016 Super Duty
12-24-2018 08:27 AM
Racerguy
1997 - 2003 F150
212
09-14-2016 06:14 PM
Balgreth
09-13-2016 09:14 PM
dpilot83
12-23-2015 09:43 AM
scottie2hottie
02-23-2010 02:28 PM
