Early 1999 Ford F-250 Tranny Problem 0733
Old 11-04-2013, 10:29 PM
Hoss5504's Avatar
Hoss5504
Hoss5504 is offline
So this morning on the way to work going up a hill the truck seemed like i was popping the throttle, When i got off work and drove it home i check the fluid and it seemed a little low so we added lucas anti slip fluid. and then drove it around it did fine then on the way back home it seemed to act like it was hopping out of gear pulled over check fluid everything seemed fine drove it around some more and going up a hill again it seemed to be bucking on me so pulled over used the bully dog programmer thing to check codes and it came up
0733
1249
1211
It was set to performance at the time so i set it back to stock drove it home no problems....Not sure what is going on but had a trip planned tomorrow but it is 2 hours away so am unsure if i should take the truck or not it has 302 thousand miles on it
Thanks in advance
Old 11-04-2013, 10:53 PM
Hoss5504's Avatar
Hoss5504
Hoss5504 is offline
I read on a forum it could be a fuel filter because he had the 1211 code and the 0733 code has anyone else heard of this?
Old 11-04-2013, 11:21 PM
Hoss5504's Avatar
Hoss5504
Hoss5504 is offline
If it helps any i do let the truck warm up before driving, and when it did it tonight it was after like a 30min drive
Old 11-05-2013, 10:28 PM
Hoss5504's Avatar
Hoss5504
Hoss5504 is offline
Does anyone have any ideas?
Old 11-06-2013, 08:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Fix the P1211 and P1249 codes and I predict the transmission will be fine. P1211 indicates fuel starvation so I would replace the filter as a first step.
IHateCommieCars
07-18-2018 07:35 PM
elkski1
08-31-2017 01:28 PM
preppypyro
15
07-13-2009 07:39 PM
overtonfisheries
10-21-2008 08:39 PM
Quick Reply: Early 1999 Ford F-250 Tranny Problem 0733
