TS Chip Installed... Trans Issues...HELP
Ok folks, so i finally had time and got my TS 6-Position chip installed... the power is definatly there, but my issue is now with the transmission. The truck will shift up from 1-2-D then the TC locks very soon, before 40 mph when it normaly does right before OD. Also when driving down a hill and letting off the gas, the RPM's normally drop to an idle. Now they stay up because the TC is still locked untill i hit the brake. Is this normal? I can see that maybe keeping the RPM's up makes the ride less "jolty" by allowing for power to be applied then let off the gas and get back on, it just seams strange to me. Any ideas would be great! thanks!!
-Robb
EDIT: as a note, I wasn't able to remove the PCM to clean the terminals, I did it with it installed, Is there a way to get the PCM out without taking out the plastic wells? Mine just wouldn't clear the sound insulation to get out...
-Robb
ehask71
07-17-2017 05:45 PM
Stilllookin
06-27-2017 08:22 PM
fordguy390
08-10-2016 08:37 PM
hijo202
04-28-2016 07:56 PM
Robbgt
01-01-2008 07:52 PM
