Superlift tru-speed sensor.....anybody?
I'm getting tired of guessing how fast I"m going all the time and want to have my speedo right for a change. I'd like to know how well the true-speed sensor works.....OR.....if it's even necessary! Can the speedo be reset to the tires manually? Tires are 35's
Originally Posted by UP_There
a search came up empty......do you have a link? thanks
http://www.fmdkinc.com/wiz.htm
If you still have the 315/75R16 BFG ATs that are in your signature, you don't need a truespeed. The dealer can update your computer with the correct tire size. The dealer can change the number of revolutions per mile to any number above 600, your tires make 601 revolutions per mile, so they will work.
If you get different tires later on ou may have to look into a truespeed though.
thats just my 2 cents
by the way the dealer rev's per mile 601 ends up being 34.6" tires.... FYI
kenny
Originally Posted by DCSpecial
Yep...BFGs don't measure a full 35", I think you can still get he revs per mile directly off of BFGs site...
The manuf. website is the most trustworthy for rev/mile. There are calculations that can be done, but they dont take into account tire squat (flatining with weight) and such.
Most manufacteres should be able to give rev/mile for a specific wheel diamater and width and pressure.
Kenny
I figured you did.
Merc is a little overenthusiastic on this stuff at times from what I've seen...
Kenny
Originally Posted by Super08
I have a tru-speed as well and have had no problems with it, works great.
Once you install these things they are all basically the same some have more features and useability then others but they are all BASICALLY the same
some you have to tweak the settings while driving while others you can do while parked and see the speed on the speedometer, some you tune with a GPS but all of them get the same result, a close to perfect speedometer reading.
kenny
