What is the best snow tire?
The best tire I have used so far in the snow was BFG'S all terrain. There are a lot of others to choose from. So what tire is better than what I have used so far? With all the people in this forum we should come up with very good information.
I am looking for a new set and am looking for anything proven to out perform BFG AT in snow!
Thanks
Thanks
If your just looking for that Winter tire, like Nikolai: said Cooper Discovery M & S are hard to beat,,plus there studdable,,lots of siping( which grip in the snow) I was looking for a bit more agressive tread.
I went with the Hankook RT03 MT tires, they are studdable (which I had done) and I really like them, right now here in eastern CT, we have about 12" snow on the ground, driveway's are all frozen over, with layer of Ice, and they do very well.
My son has the BFG's AT's on a 89' Bronco,,while light and fluffy snow they seemed great,,2 wheel drive did fine,,when the snow got heavy,,and like 8" or so,,I saw him get stuck in my driveway,,in 4X4, so thats why I looked for something different,,,Plus the BFG's are big $$$$$$ !
If you want the best winter tire, get yourself a set of Blizzak W965s. They are without a doubt the best ice and snow tire you will find, but the down side is they will wear quickly if you drive all year on them.
http://www.tirerack.com/tires/Sizes....l=Blizzak+W965
I am running Nitto Terra Grapplers and they are a lot better than BFG's in the snow and cost a lot less. I used to run BFG's and will never run them again. My nittos out perform them in every way. Yet my next tire will probably be a TOYO'S.
I also agree with redford. The Blizzarks are by far one of the best for snow. AT tires are usually good in snow but the Blizzarks are specifically made for snow and ice.
Agree with Redford, they will wear like mad on dry warm pavement, so they are not all season rubber.
If you are only looking for a winter tire then take a look at Nokian Hakkapeliitta tires.
I am running the Nokian Vatiiva AT on my F250 and they are great tires. They are actually make by Cooper in the US. I have a fairly steep driveway that with previous tires I needed 4 wheel drive if there was any snow. I have been out in the deep snow many times and only needed two wheel drive. They have a 50K mile tread wear warrenty.
Mike
Mike
