swapping out ZF-5 to a ZF-6?? any help?
anyone done this here? i have seen past threads on TDS about this but cant seem to find them anymore (when i need them). i believe the only difference b/t the two is the ZF-6 requires an external tranny cooler, which is not a bad thing! does anyone know of any other differences? any links to good tech articles or the like?
reason being is my 5 speed is in need of repair (starting to leak) and the synchro gears are going out. i would rebuild it myself as i have done one before but would really like a warraty just in case, ya know?! all the tranny shops around here wont touch it for less than $1000 (ouch!) so i figure if i am going to take the time and effort to drop my current one i might as well make an upgrade!
thoughts? comments? opinions? cash is not really an issue at this point but would like to keep it reasonable. i am figuring anywhere from $1500 - $2000 for this
-cutts-
-cutts-
A guy at work had a 99 f350 with a auto and swapped a 6 speed in. His transfer case spline was off to so he bought the case from the junk yard and swapped the shaft to make it work. It is a doable swap, it just takes time and patience. There is also a ring between the engine and tranny that has to be removed to install the 6spd. He learned that the hard way.
Originally Posted by ForemanES
I asked myself this same question just a few months ago. I found a good used 6 speed but I could have a new 5 speed for way less than all the extras it would take. The only difference in gearing is a little closer ratios but overdrive is the same as ours.
thanx guys
-cutts-
