6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
installation of PTO
Old 12-05-2007, 07:58 PM
lightonthebay's Avatar
lightonthebay
lightonthebay is offline
installation of PTO
I had the option to have a PTO put in my '08 550 but I didn't feel I needed one at the time -- Now I have changed my mind! The truck has less than 1,000 miles on it. What are my options for having one installed now? I am guessing it will cost me much more since I did not have one installed at the factory? Any advice?
Old 12-05-2007, 08:41 PM
RedDragon777's Avatar
RedDragon777
RedDragon777 is offline
someone posted a mod that all you need to do is connect some preexisting wires to the #4 switch and it will be the PTO system. Search the superduty section of this forum
Old 12-06-2007, 09:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
If you mean that you bought the truck without the PTO option installed, then it gets a bit pricier. The factory doesn't install PTOs, they install the access to have a PTO installed by an aftermarket company.
To add the PTO access now, assuming you have an automatic trans, means a new transmission. You could rebuild the one you have, I expect the cost to do that would be similar to a new trans. The case needs to be changed, and those are NOT cheap!
Old 12-07-2007, 03:15 PM
lightonthebay
Thanks Mark that is the info I needed and the answer I was afraid to hear. Oh well that option isn't atractive anymore.
Old 12-08-2007, 03:18 PM
jcm46's Avatar
jcm46
jcm46 is offline
I thought the PTO provision was standard?
Old 12-08-2007, 04:03 PM
Boaz66's Avatar
Boaz66
Boaz66 is offline
I believe the PTO priovision is standard. I have the wires for mine under the steering column but I have an automatic transmission. This has do to with the wiring harness of the truck. The truck is prewired for many things i.e the upfitter switches. They may not be installed but you can add them later. The PTO is another item that can be added later just a more expensive add on.
Old 12-08-2007, 04:23 PM
Stalwart's Avatar
Stalwart
Stalwart is offline
Nope, $250 option.
hjartland
02-07-2017 12:30 PM
FONRDAY
6.7L Power Stroke Diesel
10-05-2012 09:45 PM
Sureality
General Diesel Discussion
03-01-2012 11:34 PM
shawbran
07-07-2011 03:09 PM
EpicCowlick
04-28-2010 05:22 PM
Quick Reply: installation of PTO
