1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front Brake Diagram - 2005 F350 SD - HELP
Old 12-05-2007, 06:09 PM
travis1880's Avatar
travis1880
travis1880 is offline
Does anyone have a brake diagram for replacing the front disc brakes on a 2005 F350 SD? I am replacing the brakes have done tons of cars/trucks, Chilton is not correct and just want to get this one right.....because its mine.
Thanks for your help
Old 12-05-2007, 08:21 PM
mobilefleet's Avatar
mobilefleet
mobilefleet is offline
if you have done brakes before you don't need a diagram, disc brakes are easy. If you don't feel confident then don't try it, expensive truck to mess up.
Mark
www.mobilefleetservices.net
Old 12-09-2007, 09:24 PM
travis1880's Avatar
travis1880
I've changed hundreds of breaks in my life, thats how I payed for college. The reason I needed a diagram is to see if there is a wear indicator on this truck. The kit I purchased didn't include the indicators. This is my wifes truck and I like to have all the indicators working........
Old 12-09-2007, 09:25 PM
travis1880's Avatar
travis1880
I've changed hundreds of brakes in my life, thats how I payed for college. The reason I needed a diagram is to see if there is a wear indicator on this truck. The kit I purchased didn't include the indicators. This is my wifes truck and I like to have all the indicators working........
Old 12-10-2007, 06:37 AM
mobilefleet
go to your local dealer parts counter and ask to see a set of pads for your truck, then you can see what it should be looking like stock
Old 12-10-2007, 10:11 AM
VegasFX4's Avatar
VegasFX4
VegasFX4 is offline
There is no wear indicator on Super Duty brake pads. The brakes usually last for quite a while, depending on driving habits and conditions. Just be sure to inspect them regularly.
Old 12-10-2007, 10:19 AM
DCSpecial's Avatar
DCSpecial
DCSpecial is offline
I've never seen wear indicators on the brake pads on any of my SDs.
ken2028
06-12-2017 08:09 AM
jozan
02-13-2015 07:48 PM
lakewood
06-07-2010 04:15 PM
hjesq
05-02-2007 11:52 PM
Quick Reply: Front Brake Diagram - 2005 F350 SD - HELP
