no heat yet
Would the back vents get hot if temp not hot enough. I bought this van new in 1990 it never has reached 1/2 way alwys 1/4 or less, I have put sever thermostats in it one about a year ago.tHis has been going on sometime now but with rear air I just kinda let it go but would love to find problem. thanks
water flow from engine comes from pipe next to thermostat housing and into bottom core fitting
water flow back to engine water pump comes from top core hose and goes to water pump fitting
later model Aeros have a vacuum controlled valve in the heater hose near the core inlets to stop coolant flow when the A/C is on.
these do fail or vac. line falls off
must be working thought if you have full flow with water hose thru the core
I have a T fitting on top hose for backflushing.When I run water through with hose it seems to run fine.When I run engine with heat on cap off T water seems to run through o k.Mine is 1990 and does not have a heater core valve on heater hoses . What controls warer to core or does it pass over core all the time I dont think it does.
depends on if the outflow heater hose is before or after thermostat.
after thermostat = water flows thru anytime thermostat is open and water pumps is spinning
before thermostat= water flows whenever water pump is spinning
after what occurance or maintenance did the problem appear?
overheating, heater hose replacement, thermostat replacement, heater core replacement?
rhu05
12-22-2010 05:04 AM
DASP
1997-2006 Expedition & Navigator
12-21-2006 10:53 PM
