C.o.p.
Coolant in spark plug sockets
Originally Posted by FordCrusherGT
What are the symptoms that you are exhibiting, maybe we can help you diagnose the problem?
if I may hijack my own thread, has anyone run into coolant in the spark plug holes. I assume it is porosity seepage, I have 40K on the engine and never added coolant. I think in years past Ford had some issues(may have been in auto trannys) with thios type of leakage.
Thanks for the replies, great site.
The coolant in the plug-hole thing might be a leaky heater hose connection. Is it #4 ro 5? There were trucks with the problem, but usually in the 5.4 in the F150. But anything can happen after 7-8 years
The trick with bad COPs is that they usually only fail when hot - so, you'd have to heat them up to 180-200 degrees and then see if they exhibit any problems.
If you do wind up having a bad one eventually, buy one brand-new one and round-robin it onto each spark plug - that's one way to find a bad COP when you can't read the computer's misfire counters.
