VIN # Help
Old 06-02-2007, 08:12 PM
Leeron's Avatar
Leeron
Leeron is offline
Red face VIN # Help
I need help in breaking down the following VIN info.
E14JH701612
090 J E140 589 A 17
3600 129 4000 55
Any help would be appreciated.
Old 06-02-2007, 11:35 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
all alone in the world
should have it for you tomorrow.
Old 06-03-2007, 12:02 AM
Jimbare's Avatar
Jimbare
Jimbare is offline
dang, found my super secret decoder ring!
E14 = Econoline van, short body
J = 240 engine
H = Lorain Ohio assembly plant
701612 = June 1965 serial number (1965 model)
090 = wheelbase
J = Rangoon Red paint
E140 = Econoline van model, short body, 1/2 ton
5 = red standard interior
89 = van body style
A = 3 speed transmission
17 = 3.50:1 heavy duty axle (9 inch)
3600 = 1/2 ton GVW
129 at 4000 = certified net HP at RPM
55 = St. Louis sales district
Old 07-15-2007, 05:41 PM
JimAllen's Avatar
JimAllen
JimAllen is offline
Hope you havent put decoder ring away
I just found a Econoline in a U-Pull-it......I plan on stipping eveything I can and putting it away for my 1963, But I need help decoding the door tag.
E16AH844526
90C E160 589 C 07
3650 129 4000 22
Thanks
Jim
Old 07-16-2007, 05:30 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
E16 = Econoline van, extended body (Supervan)
A = 240 engine
844526 = April 1966 serial number (1966 model)
090 = wheelbase
C = Pure White paint
E160 = 1/2 ton Supervan model
89 = van body style
C = 3 speed transmission
07 = 3.00:1 heavy duty axle (9 inch)
3650 = 1/2 ton GVW rating
22 = Charlotte sales district
Old 07-16-2007, 09:26 PM
JimAllen's Avatar
JimAllen
JimAllen is offline
Thanks Jim, I went today and got the cross member and doghouse and radiator, going back and get the rear end tomorrow
Old 07-17-2007, 08:56 PM
Mr.FIX IT's Avatar
Mr.FIX IT
Mr.FIX IT is offline
lost vin plate
i need help i threw out my vin plate with the door. i know dumb. anyway i need help finding other id markings for a e-100, 1963, pickup. i have started to look on the frame and body but cannot find it.
thanks.
Old 07-18-2007, 04:00 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
floor board under the lip of the dog house.
right rear corner brace on some.
good luck!
Old 07-18-2007, 08:55 PM
66gpw's Avatar
66gpw
66gpw is offline
The spare tire brace is what he means. It will usually have a serial number stamped into it.
Old 11-19-2007, 01:12 PM
MONTANAANDRES's Avatar
MONTANAANDRES
MONTANAANDRES is offline
Jimbare Friend I Need Your Help With My Econoline Vin # E10th686345 Thank You Friend For Your Help
Old 11-19-2007, 07:01 PM
66gpw's Avatar
66gpw
66gpw is offline
jim has been gone for a while now. I can help here a bit.
E10 Econoline Pick up
T 170 6Cyl CID motor
H Lorain Assembly Plant
686345 Build a number sequence. It shows the truck was built in May of 1964.
Hope that was helpful.
Old 11-19-2007, 07:50 PM
MONTANAANDRES
Thanks 66gpw For Your Help My Econoline Is Getting Ready For The Road Just Trying To Get The Tittle From The Dmv. I Also Want To Put In New Tires And The Rugular Black Rims But I Dont Know What Size To Get Them . Do You Know Where Can I Get Some Caps For The New Weels That I Get Thanks Again
Old 11-20-2007, 05:36 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1964/65 Ford Motor Company Serial Numbers
1964 serial number range: 465,001 thru 580,000
1965 serial number range: 580,001 thru 732,000
686,345 = 1965.
Information Source: 1964/72 Ford Truck Parts Catalog
Old 11-20-2007, 12:53 PM
MONTANAANDRES
Thanks Numberdummy One More Question I Want To Put In This 65 Motor Into A 63-64 Pick Up Will It Fit In The Same Position As The Othere One? If Not Would I Have To Do Many Modifications In Order For The Engine To Fit Please Let Me Know
Old 11-20-2007, 10:12 PM
MONTANAANDRES
Thumbs up
One More Question What The Ok Temputer For The Engine Bucause Mine Runs And It Gets To 210 Please Help Thanks
Quick Reply: VIN # Help
