E14 = Econoline van, short body
J = 240 engine
H = Lorain Ohio assembly plant
701612 = June 1965 serial number (1965 model)
090 = wheelbase
J = Rangoon Red paint
E140 = Econoline van model, short body, 1/2 ton
5 = red standard interior
89 = van body style
A = 3 speed transmission
17 = 3.50:1 heavy duty axle (9 inch)
3600 = 1/2 ton GVW
129 at 4000 = certified net HP at RPM
55 = St. Louis sales district
I just found a Econoline in a U-Pull-it......I plan on stipping eveything I can and putting it away for my 1963, But I need help decoding the door tag.
E16 = Econoline van, extended body (Supervan)
A = 240 engine
844526 = April 1966 serial number (1966 model)
090 = wheelbase
C = Pure White paint
E160 = 1/2 ton Supervan model
89 = van body style
C = 3 speed transmission
07 = 3.00:1 heavy duty axle (9 inch)
3650 = 1/2 ton GVW rating
22 = Charlotte sales district
i need help i threw out my vin plate with the door. i know dumb. anyway i need help finding other id markings for a e-100, 1963, pickup. i have started to look on the frame and body but cannot find it.
thanks.
jim has been gone for a while now. I can help here a bit.
E10 Econoline Pick up
T 170 6Cyl CID motor
H Lorain Assembly Plant
686345 Build a number sequence. It shows the truck was built in May of 1964.
Thanks 66gpw For Your Help My Econoline Is Getting Ready For The Road Just Trying To Get The Tittle From The Dmv. I Also Want To Put In New Tires And The Rugular Black Rims But I Dont Know What Size To Get Them . Do You Know Where Can I Get Some Caps For The New Weels That I Get Thanks Again
Hope that was helpful.
1964/65 Ford Motor Company Serial Numbers
1964 serial number range: 465,001 thru 580,000
1965 serial number range: 580,001 thru 732,000
686,345 = 1965.
Information Source: 1964/72 Ford Truck Parts Catalog
Thanks Numberdummy One More Question I Want To Put In This 65 Motor Into A 63-64 Pick Up Will It Fit In The Same Position As The Othere One? If Not Would I Have To Do Many Modifications In Order For The Engine To Fit Please Let Me Know
