1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 Steering Glitch
Old 11-24-2007, 08:46 PM
Bassman60's Avatar
Bassman60
Bassman60 is offline
Question F250 Steering Glitch
I might be wrong, but it seems to me that my F250 has about 3/4 to 1 inch play in the steering wheel. I have had the front end checked and the drag link changed, but still seems to be that play. I'm wondering if it could be the steering box. Other than this it's an awesome truck. Beefed up rear springs and air bags. The boat and camper don't tell the 7.3 anything. Just trying to keep it on the road seems to be a little tougher than necessary. Any suggestions greatly appreciated.
Old 11-25-2007, 12:08 AM
ameinig's Avatar
ameinig
ameinig is offline
How many miles? Mine has 168k and I am think my box is bad. You can turn the steering shaft back and forth quite a bit under the hood before it stops.
Old 11-25-2007, 12:33 AM
Bassman60's Avatar
Bassman60
My F250 has 79,000Approx) miles on it. With the wheels off the ground it has none to very little play. When I get the weight of the truck on the wheels the steering wheel turns quite a bit before it stops.
Old 11-25-2007, 10:30 AM
playsinmud's Avatar
playsinmud
playsinmud is offline
Saw a truck the other day with this issue... Turned out the pitman arm was loose on the box. Easy fix just can't belive how loose it had gotten. Little heat and a big wrench sucked it right back up onto the box..
Old 11-25-2007, 10:35 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
From the factory, there have been Superduty's with loose steering boxes.
The adjustment on the box might tighten it up some. Be careful, you can lock up the box if you tighten it up too much.
aldridgec's Avatar
aldridgec
aldridgec is offline
Wow. that's an odd one.
Old 11-25-2007, 03:45 PM
Bassman60's Avatar
Bassman60
Pitman Arm
I'll check this out. Thanks
Old 11-25-2007, 03:50 PM
Bassman60's Avatar
Bassman60
Steering Box
When I first bought my Truck (used) it had 40,000 miles. The dealer at that time "tightened up the box a little". Would the box have a tendency to loosen again and/or is this a common periodic adjustment? Thanks
Old 11-25-2007, 04:56 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The box does wear over time - especially if you do a lot of stop-and-go and turning.
How many miles do you have now?
The problem with adjusting it too much as it wears is, most of the wear is at the center of the steering box movement. When you tighten it up to stop wandering, when you do have to turn the wheel to the end, it will bind up at the ends. Which is bad.
Old 11-25-2007, 05:04 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Also check the steering box is not wiggling against the frame where it is attached, this is another rare place for play to develop. You can check by parking, asking someone to crank the wheel back and forth while you are parked and watch the box and pitman for play.
Old 11-25-2007, 05:23 PM
Bassman60's Avatar
Bassman60
Steering Box
I have 85,320 miles on the truck (thought it was less). I do a lot of turning (backing up the boat, loading and unloading camper, etc.). Slide in Camber weighs 2100lb. Tow the boat and haul camper at the same time occasionally. Really noticed the wandering today while hauling boat. (new tires yesterday). Wandering was there before the new tires. Check the steering box for tightness on the frame. Looks OK. Pitman arm looks OK Also.
Last edited by Bassman60; 11-25-2007 at 05:25 PM. Reason: Add for loose Stering Box
Old 11-26-2007, 01:41 AM
5.4L to Freedom's Avatar
5.4L to Freedom
5.4L to Freedom is offline
Sounds like the early signs of "death wobble". My truck had similar symptoms but was corrected with a new steering dampener.
Old 11-26-2007, 01:44 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Good point.
To the original poster, does this wandering become a problem when you are going over bumpy roads, railroad tracks, etc? And the rest of the time, it's not "all that bad" ???
Old 11-26-2007, 05:40 PM
Bassman60's Avatar
Bassman60
Wobble
Worth Checking out. The Wandering is really consistant. Bumps or uneven surfaces don't seem to change the status. The only time I notice is when making small corrections (usually to stay in lane). I can turn the wheel approx 1" and the truck does not respond untill I get passed that 1" point and start feeling resistance. Then the truck will respond and when I have corrected, then back the other way it's the same. No response until the resistance is felt.
Old 11-26-2007, 05:49 PM
ameinig's Avatar
ameinig
ameinig is offline
Same with mine. Anyone know what a new Ford box costs?
Quick Reply: F250 Steering Glitch
