what size tires can the 300 handle?
I have a 1978 f-150 4x4 short bed, with a 300ci. I-6, manual trans., np205 transfer case, and a Dana 44 front and Ford 9" rear with 3.55 gears. At this time i have 33x12.50x15's on off set rims, and i want to put in a Detroit Locker ( or some type of limited slip) in the rear (with a mini spool up front) soon. But my question is; What are the biggest size tires that this drive train can handle? I plan on getting 33x12.50x15 Super Swampers but i would like to possibly get some 35x12.50's or the Super Swamper 36x12.50's. Just keep in mind that its a 1/2 ton drive train with a 300ci. Oh and i should mention that i go 4 wheel'n about every 2 weeks (so its not like i all ways have it on the trails) also because i have school, i use the truck as a daily driver.
You have your lockers backwards. A spool in the front will put you in a ditch the first corner you take. If anything, a spool in the back and a locker up front would be much better, though a locker in back and a limited slip up front would be more streetable.
As for your actual question, I wouldn't go over 33's with 3.55's. I think 33's would be better with 3.73's myself, and 35's with 4.10. So if you are to switch, i'd go with 35's and 4.10, but your current 3.55's will work with 33's. Any larger and you'll give up a bit too much first gear acceleration.
-=Whittey=-
-=Whittey=-
I don't know about the performance, but I found this truck on ebay kind of interesting. 300 I6 and (I'm guessing) the M50D.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1820461940
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
I have a 84 bronco w/300cid & NP-435 & NP-208 and I am running 35x12.50x15 with a 6" lift and for now the stock gears 3.55 I will be going to 4.56's but I have no prob's off-road on road I have to keep my foot on the gas to stay at 65mph or more and I have to use 1st starting on hills. But it still kicks butt on rocks!
chogue
08-17-2012 03:09 PM
mdjohnson
Offroad & 4x4
02-23-2006 07:32 PM
