Transmission Fluid Quantit
Originally Posted by ramon1943
2005 F250 Super Duty, 5-speed Torqshift. Need to drain and change remote filter. What is the refill quantity of fluid (qts) required after draining and changing the filter? Thanks.
From the 2005 owners manual, which can be downloaded here:
http://www.analogstereo.com/pdf/om/f...anual_2005.pdf
Automatic transmission fluid - Motorcraft MERCON SP ATF - 17.5 quarts (16.6L) (includes remote filter element change)
If you are dropping the pan & changing the remote filter it will take 7-8 qts as the T/C & trans cooler will still be full of fluid.
If you flush the transmission as per the procedure in the 6.0 tech folder, then it will take 18-20 quarts to fully flush and fill the transmission, T/C, cooler and lines.
Here is the link to the transmission flush procedure from the 6.0 tech folder.
http://www.truckblog.com/story-582-h...t_transmission
gene daniels
08-28-2014 06:27 PM
IAMFORD
01-16-2006 04:47 PM
