F-150 rear glass?
F-150 rear glass?
On our 01 f-150 the sliding rear window started leaking water in to the rear seat. Had to remove headliner and remove the rear sliding window to replace the buthyl (sp) sealing strip. Now I have to do the same to the 05's rear sliding rear window. It started leaking in just about the same area the 01 leaked from. Is it just our 4 wheel drive trucks? We use them on some ruff construction sites and I was thinking maybe because of flex while driving around these places is causing them to seperate from the cab.. Thanks vapor
It was for sure coming from the rear glass sealing strip. I did check with a garden hose. My son would just let the water go around rear glass only and I was in the back seat watching it come in. As I said now the other truck is doing it. It don't take long to pull the rear glass. I got "learning" form the first one I did. Just wasn't sure if we are the only one's to have them leak like this. we do work the snot out of these trucks..
I made an earlier post about noise from what seems to be the center of my rear window, so far, no leak. ( 2007 XL non-opening rear window) I hear a little noise, and maybe we are onto something here. Just where was this leak on the gasket, top center, right, or left, and also, what was the area that needed sealed on the 3rd brake-light? (Whole assembly?) I like my truck, and it is nice to be getting piddling things fixed.
Originally Posted by BigBlueMacDaddy
Rats, I now see that your leak came from the sliding window itself. I thought in your first post that it may have been the seal holding the rear window in. Still, any more info on the 3rd brake light leak?
