I have a dumb question about a 1950
i put the bed off of an 3/4 ton on mine before making it a 1/2 ton and it looked fine . you will have touse an 8 foot bed though as the 1/2 tons i have seen are all shorter 6 foot beds and they are'nt as wide or as tall as the eight foot . this is with the 53 - 56 one of the guy's with the older trucks will be along anytime now with the correct info .
Originally Posted by F6Guy
Holy Crap!!!!!!! were did he find those wheels?
on
I went from an F-3 to an F-1 but going to an F-1 from an F-4 would be harder since the bigger truck frame is a deeper channel and heavier. The F2/F3 frames are very similar to the F1s... just longer. It could be done, however. I remember seeing one done sometime back here on FTE by someone overseas (may have been UK or Australia). The F-4 that he converted also had a custom step up in the rear part of the frame above the axle. The F-4 frame is straighter in that area (no kickup) than the F2/F3 and it would be very high in the rear end if that were not done.
1950F47
13
04-13-2017 12:18 PM
farmall_7
10-15-2015 06:22 PM
gtotiger65
10-12-2015 09:31 AM
