2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Mounting your brake controller???
Old 05-03-2008, 06:54 PM
ltatkinson's Avatar
ltatkinson
ltatkinson is offline
I usually mount my contoller in the middle under the dash. But in this truck has a center console. Could you please give some ideas where you mounted your brake controller. Thanks
Tim
Old 05-04-2008, 10:17 AM
chuck s's Avatar
chuck s
chuck s is offline
Tekonsha Prodigy velcroed to the dash (using the pocket). Didn't stick well, though.
Replacement Tekonsha P3 below the dash using an existing dash bolt:
If you have a lesser controller invest in one of these!
-- Chuck
Old 05-05-2008, 01:31 PM
ltatkinson's Avatar
ltatkinson
The bottom of my dash looks different from the pix above and that is my problem. Mine is not flat like those.
Tim
Old 05-05-2008, 03:17 PM
ltatkinson's Avatar
ltatkinson
Oops had a brain fart mine looks the same. I installed mine on the oppisite side of the steering wheel about half way up. I will try to get some pix.
Tim
Old 05-12-2008, 07:22 PM
Efinn's Avatar
Efinn
Efinn is offline
See the ideas in this previous thread
I posted pics of my mounting in that previos thread. We've used it a few times now and I'm quite happy with the location and visibility when towing.
https://www.ford-trucks.com/forums/6...ng-2007-a.html
HTH, Eric
Old 05-12-2008, 07:42 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
I originallly mounted mine in the same spot in both my explorer and my expedition, but before my cross country drive towing a 7K trailer, I decided to move it to the little tray under the stereo. Boy am I glad I did!!! I was on a road that was 55mph, but had stoplights every couple of miles. The roads were wet, and I was coming down a hill when the light turned yellow!! I was maybe 50 yards away, too far to push through the light, but close enough for me to worry. I ended up using the "chicken" switch on the controller and a my truck brakes, not knowing how the anti-lock brakes take a trailer into consideration. If you had to do that with the controller mounted down at the bottom left, it would not be safe or practical, nor convenient for a quick response. If the inconvenience of losing an inch off the pretty much unusable tray saves you from a jack knife or hitting another vehicle, thats well worth it in my opinion. I didn't fully slide the lever, just to about 60% where I could feel the trailer brakes significantly more than the truck brakes. Better to let the trailer slide than to have it start pushing the truck out of control.
MikeMcCasland
1999 to 2016 Super Duty
08-09-2009 08:09 AM
Hiflyer746
05-19-2007 01:28 PM
rob_nc
2004 - 2008 F150
05-14-2007 11:20 AM
SHANE_2
2004 - 2008 F150
18
10-16-2004 02:25 PM
bullhauler
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-18-2002 09:08 PM
Quick Reply: Mounting your brake controller???
