Upfitter switch for High idle
#76
Not sure about any switched power under the dash, but there is a switched power wire going to the trailer plug. The guys at the dealer where I got my cap did that for the lights... As soon as I got a chance I wired them to a switch on the dash (not an upfitter, home brew jobby but does the same thing - lots of other stuff on the panel besides the on/off switches though).
On a side note, I just started reading this thread and realized it was an old one from 07. Anyway, theres a post on the first page talking about how there is a buit-in ide up feature if you idle longer than 120 seconds when cold or something. Mine does this all the time in the morning. The RPM's go up over 1000 when this happens. If it happens automatically, why put a switch in for it? Maybe I don't let mine idle long enough to see it drop back down but it does kick the RPM's up after a short time when I first start it.
#77
#78
#79
so I just hooked up the wires as described on here and everything works great. Is it ok to just twist the wires together then wrap with elec tape? I figure there isnt much draw on the connection so I should be ok??? Let me know if not. By the way will the truck warm up faster now that this is done on those cold mornings and can it idle now for however long I want it to with out concern of wet stacking?
Thanks for the help
STM
Thanks for the help
STM
#80
#82
#84
#85
It's easier than you think, I did mine a couple of days ago. Just pop off the plastic cover under the steering wheel, find the green/yellow wire in the large bundle of wires just above the Ebrake (they are bundled together and all have a black heat shrink looking end on them) then right above that bundle you'll see another group of 4 wires, I forgot the colors, but there is a solid brown one in that group (the brown one is for upfitter switch #4). Just make a jumper wire about 3 or 4 inches long and connect the green/yellow to the brown wire. It works! The E-brake has to be set and the transmission in PARK. Mine revs up to about 1200 RPM. If you touch the brake pedal, it will cancell it out.
OH I AM IN ALASKA SO I DO NEED THIS MOD!! IT GETS -50 HERE!!!!! PLEASE HELP!!!!
#88
#89
I know this is an old thread, but I am new to the site and new to Diesel engines! I just bought a 2010 King Ranch F250 6.4L and I found this site while trying to familiarize myself with this engine. There is a lot of good info on this site!
I hooked up the high idle to Aux 4 and it works great. Just curious when you guys use it though. I sometimes park for extended periods during duck season in Florida, and I pictured using it to the run the A/C while parked/sleeping in the truck. BUT...should I run it at high idle continuously for hours, or intermittently throughout the night? Thx. for the info.
