Taking Parts of a Flathead
Old 10-23-2007, 06:37 AM
rcav8or's Avatar
rcav8or
rcav8or is offline
If you use it, SUPPORT IT
Hi, all...
My '51 F2 Flathead was missing some parts, manifolds, cleaner, etc.
I am going down tomorrow to Kentucky to pick apart a flathead, with a rod through the pan. I can take everything I can get off the motor.
I will have about 6 hours get everything I can off the motor. I have never torn one down. The motor is still in the truck, and I will not be pulling it out. I need some suggestions...
What all should I take? I will take the obvious - head, genny, all the outside stuff I can get off, manifolds, distrbutor, etc.
Should I try to remove the valves/springs/lifters/etc? How hard can they be? I read up on how to remove them, and have the tools, but is it worth it? Whatever I don't need on mine, will be cataloged and stocked as spares.
I may be able to lift the block off the front mounts - should I take the pumps? Front cover? gears behind the cover?\
Any secrets to taking off the front pulleys?
Anything I've forgotten?
How long should it realistically take?
I really want to get all I can, as an opportunity like this doesn't present itself every day.
Thanks in advance, for any help/suggestions/hints/comments you can give me. As I said, I am leaving here at 4:00 am tomorrow morning, so time is of the essence...
R
Doc
63
12-17-2013 03:43 PM
Kanepfc
11-23-2013 06:16 PM
Stickid
15
02-07-2010 09:46 PM
rcav8or
11-25-2007 05:57 PM
restoringmy46
Flathead V8 & Flathead 6
03-13-2006 05:59 PM
Quick Reply: Taking Parts of a Flathead
