This may be a dumb inquirery but---What do ya'll mean when refering to a reverse 105?? Please enlighten a newbie thats willing and most interested in learning as much as I can about the FE. Thanks in advance.
ClodBahls 74 f-250 4x2
"camper special" 390/c6/4:10 dana 60
There were a few different foundrys that cast FE and FT blocks. Blocks cast with the "105" reversed were cast at MCC Michigan Casting Center. Other foundrys were Dearborn, Cleveland and Geelong. Sheffield was another but was the aluminum foundry.
The story that I have heard many times over that the person that was making the mold did not put the 105 backwards like he should have, so when a block is poured you see a reverse image.
The reverse image block has more webbing in the crank area and is considered my many as stronger and better. I don't recall any complaints for any FE block used for street use.
The only 105 block I've had with a 390 bore, was hard pressed to be bored .030. Main webbing strength means nothing if you cannot bore the block oversize.
I really have no idea sorry. Most std web blocks were slated for the std passenger cars. The HD blocks were for performance and heavy duty applications. But I've seen a pretty good mix and match of std and HD blocks in both applications in factory original cars. Anything is possible.
