Disable the dome light delay?
Is it possible to kill the dome light delay once the door has been opened and shut? I have run into a problem with my Viper alarm where the door trigger input to the alarm is using the dome light. (Don't ask me why this is what DEI suggests using.) Anyway, I can't arm the Viper until the dome light is out as it sees it as a door being open. Any ideas?
Yeah, I have the same problem on my remote starter. I bypassed it but would prefer not to. I'm going to do two things because I am ****. Install a diode so that when the parking lights flash, the warning dinger doesn't ding b/c it thinks I left the lights on.
I believe there are two door ajar switches in the driver door. One for the light and the other for the door ajar stuff like warning chime, light in the cluster etc. I am going to look into tapping that for the door ajar instead of the lighting one.
While it is annoying i have the same issue. I could hsve spent the time wiring so i didnt have the issue but i just get used it. Since you found that you can bypass the chirp then you should be fine. As soon as the dome light turns off the alarm will arm the door triggers (Domelight). So your alarm isnt being compromised.
ufvj217
Electrical Systems/Wiring
10-22-2015 02:14 PM
ufvj217
1999 to 2016 Super Duty
10-22-2015 05:14 AM
kawasakiklx1
09-03-2015 09:33 AM
