60 gallon GAS tank
60 gallon GAS tank
I just got back from picking up my 08 f450 from installing a new 60gallon fuel tank. Man that is a big tank. This should give me a little more range when towing my 5th wheel. The tank manufacture is Transfer Flow.
Does any one out there know if the computer can be reset so i can get an accurate range of mileage.
I'm think about the 46 gallon tank for my 250- when I asked them a month ago they could only do it for trucks up to MY 2002. They didn't know when or if they'd have a patch for the new computer unfortunately. A recent thread here by someone who put in a different brand of larger tank said the same thing.
Originally Posted by blackhat620
Originally Posted by mattebury
Wow, 4 inches below the frame rail. Probably something you don't want if you ever go off road.
Originally Posted by jteller
Not cheap though, are they? That's a pricey mod.
The tank does hang low. But the installer said it was a straight switch over.
I chose to go with the replacement tank over the in the bed tank as i need all the space i can get in the back of the bed.. But i also saw that transfer flow makes a tool box tank that holds 40 gallons that auto fills the main tank when it gets at half way.
The replacement 60 gallon tank cost me installed $1360.00. It is a little pricey but my rang just increased 36% that is a lot when you are towing a 18000lb 40ft 5th wheel and you just cant pull in to any gas station, and the truck only gets 7mpg on average towing
SouthBoundandDown
6.7L Power Stroke Diesel
11-26-2014 09:10 AM
StanleyZ
6.4L Power Stroke Diesel
16
10-23-2013 05:47 PM
abyars111
15
09-28-2013 04:16 PM
