Iowa Chapter Join Chapter, Leader:
Cummins engine
Old 10-28-2007, 06:58 PM
goodgord's Avatar
goodgord
goodgord is offline
Cummins engine
If I install a cummins in my F350 does anyone know for sure if the 4R100 tranny will handle this power. I know it would need a different torque converter and a higher rear end. Right now it has a 5.4L gasser.
Thanks
Gordon
Old 10-28-2007, 07:35 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
as setup the 4R100 behind your 5.4 would NOT hold a cummins, heck it wouldn't hold a stock psd thats why Ford upgraded the 4R100 when it was used behind a 7.3 vs what was used behind a 5.4
Old 10-28-2007, 07:37 PM
goodgord's Avatar
goodgord
goodgord is offline
I was giving thought to installing a dodge tranny along with it. Might be cheaper also
Old 10-29-2007, 06:49 AM
fellro86's Avatar
fellro86
fellro86 is offline
It makes things a bit simpler if it is a 2wd. 4wd is a crap shoot as to the better way to go, but the 4R100 would still have to go. The claim is that the Ford diesel trannies don't hold up, but it also depends how crazy you are going to go with the motor. Also, a consideration is the bell housing mounting, it may be more trouble to get an adapter plate made. They are available for the diesel bells, but not as much for the small gas bells. I don't imagine they kept the bell the same as the 302, but even then, it limits the torque converter size, and the gas converter won't work well with the Cummins.
Old 10-29-2007, 06:59 AM
goodgord's Avatar
goodgord
goodgord is offline
Thanks guys,
I don't want any huge problems so I guess I will find a complete setup out of a Dodge.
Old 10-29-2007, 07:12 AM
fellro86's Avatar
fellro86
fellro86 is offline
Best way to go is get the whole truck, all the small stuff is well worth it. I bought a roll over with everything I needed, and then some, since it also had the gear vendors unit as well.
uh60
General Diesel Discussion
12-04-2016 10:45 AM
e4odcummins
Engine Swaps
11-16-2016 07:28 PM
1949f1
09-10-2016 12:07 PM
guns
08-09-2016 05:11 PM
Dillin
18
03-20-2009 02:47 PM
Quick Reply: Cummins engine
