cummins conversion
Old Oct 13, 2008 | 07:10 PM
Dillin's Avatar
Dillin
cummins conversion
Im looking to put a cummins in my 1965 ford f100 with 4x4 and i was wondering if anyone else has any information on that i have only herd of one guys doing so i didnt know if there was anyone else out there?
Old Oct 13, 2008 | 09:31 PM
billy12360's Avatar
billy12360
ive been thinking about doing it... but right now... my ideas are to take a newer f-350 long bed crew cab... and find 2 decent slicks.... take the body off the f-350.... weld the 2 cabs from the slicks together...{making it a crew cab} and then setting that on the f-350 with the power stroke already in it... along with disk breaks already up front... power steering and power breaks... plus more upgrades for the suspension and ride quailty... but it will probablly turn out to be a very expencive slick in the long run... just for the f-350 or f-250... but i would prefer the one ton suspension...
if you do decide to swap in the cummins good luck and keep us posted on it.....
Old Oct 14, 2008 | 07:12 AM
jowilker's Avatar
jowilker
Dillin, weight is a huge factor in selecting a diesel for a half ton. Keep that in mind while searching. Your truck is old enough that emissions are not an issue in most states. A 4 cylinder turbo could be a good choice if packaged right.
John
Old Oct 14, 2008 | 07:38 PM
bigblockford_390's Avatar
bigblockford_390
A 5.9L six clyinder Cummins diesel weights in at about 1100 pounds. That would be a lot of weight for a half ton pickup I would think.
The other thing to consider is the cooling needs of the engine, you have to have a good sized radaitor with good air flow to keep the engine cool.
With some time and money anything can be done, but you might be better off looking for the 3.9 4 cylinder Cummins which is just a 5.9 missing two cylinders.
Jeff
Old Oct 14, 2008 | 09:21 PM
Dillin's Avatar
Dillin
ya you guys dont have to worry about weight when i do this im putting one ton springs under it two so it aint no big deal, i was just wondering on information of doing it. thank alot though
Old Oct 15, 2008 | 06:12 AM
jowilker's Avatar
jowilker
Dillin, You might want to research it a little more in depth, but bearings and other issues com into play when adding extra weight. My first thought was to build it on a heavier 70s chassis but a 65 4x4 is built off the 61-64 style.
Moving the sheet metal to a newer diesel powered chassis could still prove to be a better move in the long run. The engineering would already be done. IMHO
John
Old Oct 15, 2008 | 09:08 AM
bigblockford_390
I would think the easiest and cheapest way to complete your swap would be to buy a mid 90's Dodge 3/4 or 1 ton pickup that has body damage as it will be cheaper in price. Then either transplant your 65 body to the Dodge frame or remove all the running gear from the Dodge and transplant it onto your 65 frame.
That way you get all the pieces that you will need in one shot and my guess in the long run it would save you a lot of money. Then you sell off what parts you do not use and gain back some of the money you spent on the project. A lot of people on this forum would agree that buying a donor truck is the best way to go when completing any kind of swap.
Jeff
Old Oct 19, 2008 | 12:20 PM
bigbeerbb's Avatar
bigbeerbb
Try this site: 4btswaps.com
lots of good info
Old Oct 20, 2008 | 05:26 PM
80F100man's Avatar
80F100man
Just go small, they say, too much # they say, a 460 weighs in at around 950# to 1,000#......what's another 150# or so, heh,heh... go 4 cyl. Mercedes diesel, fit the space, not much more weight, but you'd have to go with the same tranny, clutch, etc. too.....not many Mercedes diesel vans in America tho' are there? .........they're all over the place here...I'm thinkinng of 2.7Litre v-6 diesel & automatic for my '79 F100 I have over here....
Old Oct 20, 2008 | 05:28 PM
80F100man's Avatar
80F100man
You could just find a diesel out of a old bread delivery van....4 cyl. diesel and that 5 spd.----- just a thought....
Old Oct 20, 2008 | 07:54 PM
jacks61ford's Avatar
jacks61ford
if someone decides to put the 4 cyl cummins i have the flywheel bellhousing and trans that came out of a ford chassis so it should be a direct bolt up
Old Oct 20, 2008 | 10:59 PM
bigblockford_390
I think you will find the 460 weights a lot less, more like 650 pounds so in reality the 6 cylinder Cummins swap is more like an extra 400 pounds.
Jeff
Old Oct 21, 2008 | 05:57 AM
jowilker's Avatar
jowilker
Jack That is kinda a broad brush stroke statement, what Ford chassis, what transmission?
thanks
John
Old Oct 21, 2008 | 06:56 PM
Hakk's Avatar
Hakk
YES, this is the way. At one time I was spending a lot of time looking at used Fords for a good drivetrain for my '65. Vans and other work vehicles are much cheaper than pickups. People buy pickups as "male ego" vehicles, but vans are not cool.
I would say it's easy to stretch the frame if necessary, but getting a complete drivetrain can be quite expensive. I think you should only look at the drivetrain and try to stay away from the "sexy" pickups if you can.
Old Oct 21, 2008 | 07:52 PM
jacks61ford
Jack That is kinda a broad brush stroke statement, what Ford chassis, what transmission? it came out of a bread truck but has the granny low four speed trans bell housing flywheel block plate and starter i used the motor in my scout but put a 727 behind it..
