how much oil does my 97 460 hold
...been sitting here thinking about it today. i bought 5 quarts for it and was going to change it myself for. ended up taking it to **ffy *ube. it's a long story why and i know i shouldn't, but thats not what this is about.
does it hold 5 or 6 quarts? i've seen both listed in different places. pretty sure my manual says 5, but i want to say i've also seen 6 listed. anyway, that place charged me for an extra quart (6 total) and the dipstick reads a little high i think.
seems to run fine, should i drain some out if it only holds 5? (fyi - this was a week or two ago)
well looking at All Data it says 5 quarts for the motor and add one if you are changin the filter. if your still kinda skeptical, fill it with 5, then run the motor for about a minute and shut it off and check the dip stick, add a little bit of oik until you get it to where you want it on the stick.
In my truck the motor works a little harder than most, so i want to hold all the extra oil i can,and keep it cool as i can plus i run royal purple, rather then that no reason... If its past the full mark i would drain some out to be safe and keep the extra pressure off your seals if you have no oil leaks, if you have some oil leaks i wouldnt worry about it.... But i know if i put 6 in my truck with the stock filter it was half a quart to much, and with the big filter i can run 6......
i have a 97 f250 with a 460 and mine takes 7 quarts of oil and i always change my oil filter with a k&n a little more expensive but i got it for free one time when i bought an air filter and they work better than any other oil filter ive used and i change my oil every 5000-5500 miles and its still pretty clean.and i toy a lot of trailers to the desert and dunes loaded with sand rails and dirt bikes.
hey i got a question my lil sis truck is having a problem it is a 98 f150 and i think it is a 3 something i forgot, but anyways it says it takes six, so i put six in and ran the vechicle for the filter to fill which the filter is really tiny so it shouldnt took maybe a half a quart, well next thing i know there is no oil read on the dip stick, so i poor in another quart no read, and than i poor in the 8th one and i get a read but only half way up, i was amazed how much oil it took, is that normal
