I am about to set the 460 in the bronco, I am using the L&L motor mounts. would it be better to set the mounts on the frame perches and then set the motor on them. or bolt the mounts to the motor, and then set the motor in?
I bolted the L&L mounts to the motor first, then lowered it into the Bronco. It was much easier to reach the bolts that way, vs inside the engine bay. On my 84 I had t remove the passngr-side exhaust manifold to fit the 460 in there, then massage the firewall to get it to fit. Not an issue with the L&L headers. Good luck ,JSM84
