1978 - 1996 Big Bronco
setting the motor in
Old 10-15-2007, 08:19 PM
79-400-POWER's Avatar
79-400-POWER
79-400-POWER is offline
I am about to set the 460 in the bronco, I am using the L&L motor mounts. would it be better to set the mounts on the frame perches and then set the motor on them. or bolt the mounts to the motor, and then set the motor in?
Old 10-16-2007, 12:46 AM
mrknight01's Avatar
mrknight01
mrknight01 is offline
I like to do one of each. The one on the block will help line it up and the other will already be loose in the frame so you don’t have to fight it.
Old 10-16-2007, 07:50 AM
MBBFord's Avatar
MBBFord
MBBFord is offline
The way I've done it, and helped others do it was with both mounts on the frame.
mrknight01's idea sounds pretty good though.
What kind of build did you do to the 460?
Old 10-16-2007, 03:47 PM
79-400-POWER
bored . 060 over, 10.5-1 compression, mild cam, 50,000 volt HEI distributor, 750cfm holly,
Old 10-17-2007, 07:46 PM
justshootme84's Avatar
justshootme84
justshootme84 is offline
I bolted the L&L mounts to the motor first, then lowered it into the Bronco. It was much easier to reach the bolts that way, vs inside the engine bay. On my 84 I had t remove the passngr-side exhaust manifold to fit the 460 in there, then massage the firewall to get it to fit. Not an issue with the L&L headers. Good luck ,JSM84
WALFORD'S 56
Engine Swaps
01-17-2010 03:44 PM
o1fstm
07-16-2008 05:41 AM
oldmansimek
12-25-2006 11:50 AM
Thomsen
Offroad & 4x4
06-03-2005 02:47 PM
TheLastRebel
13
10-23-2004 05:54 AM
Quick Reply: setting the motor in
