First Questions, 53 Lock/Ignition
Originally Posted by tip49
P3 I'm with you ; the original push button start stays in my truck.
Tom
Tom
When I pushed that "junk" button. This rumbled to life and I got all giddy inside.
53OTM have you installed that switch yet? Mid50's HotRodtrucks, and Carolina Classic sell a kit that gives you two door lock cylinders along with an ignition switch all with matching Key. Might save you a little hassle down the road. Most of us have scars from lessons learned, some physical, majority MENTAL
Tacson;
I'm liking your air intake ; did you fab mounting bracket or modify an existing one from the donor ?
Also would be interested in your throttle pedal and linkage; I installed a hanging pedal from an Explorer but am waffling now; may try to use floor mounted pedal and adapt hanging liinkage.
Tom
Tom
Received 1,353 Likes
on
Originally Posted by Jag Red 54
I used a new switch and bypassed the push button. Then the push button became the horn button for the aaOOOOOGA monster! Jag
I can`t remember if my 56 M100 even had a starter button or it was on the key...
It`s been off the road 4 years now, hopefully by spring it will be reborn and driving better than ever!
on
yepper on the two door locks on the custom cabs as the now gone pos rust bucket original cab and doors of my 55 were / are a custom cab , and it had two door locks . i kept all the goodies for the locks so if and when , and if i can find 'em now ican have the drivers side installed . i love the push button myself and it's a great antitheft as noone other than me and the grandkids know thats what its for . and i like the look of the original dash . also the clip for the door lock is on the door jamb and dont be suprised if you mangle it trying to get her out ! i love your truck by the way .
#29
I'm keeping the push button. But, when I push mine, (bwahahaha) you will hear the sound of a caged lion wanting out (I still love that I have a CAT diesel in my 55). Yes, the custom/deluxe cabs had two door locks, and yes, the myth is true...Ford used the passenger side for "safety." Building a truck around a small part, I agree. i bought a 74 LT8000 dumptruck and disassembled it to build a (what started as a 53, but is now a 55) mid 50's Ford Big Job around the CAT (yeah, still love the CAT) motor, and the 5x4 trans.
