2002 Steering Problems
Old 10-01-2007, 10:25 PM
insulation man's Avatar
insulation man
insulation man is offline
02 v10 4x4 replaced ball joints both sides tie rods stabilizer tires/brakes/rotors steering to me seems a little sloppy. has 175000 miles i was thinking about the steering box but not sure. any ideers thanks
Old 10-02-2007, 09:29 PM
VaSheriff's Avatar
VaSheriff
VaSheriff is offline
Originally Posted by insulation man
.... i was thinking about the steering box but not sure....
With the search feature not working now, you can't find the fix. But there is a steering box fix out there. Somebody familiar with this fix will chime in shortly and answer your question I'm sure.
Old 10-03-2007, 12:52 AM
i eat hybrids's Avatar
i eat hybrids
i eat hybrids is offline
I remeber reading a thread a while back and a guy was talking about adjusting your steering box? Do u think that is what he needs to do?
Old 10-03-2007, 07:04 AM
DSMMH's Avatar
DSMMH
DSMMH is offline
I adjusted my steering box at 40,000 miles and it made a huge difference. Here is what I did. Since you have a 4X4 the steering box should be the same as mine. On top of the steering box there is a 5/8 nut locking an allen head bolt. Since there is not enough room to go underneath and adjust the box, I took a 3/8 drive 5/8 deep socket, a universal, a long extension and ratchet and came in from the top. Loosen the 5/8 nut. It will be TIGHT. Put the allen wrench in the bolt and turn CW looking at the top of the box about 1/2 to 3/4 turn. Tighten 5/8 nut and drive it. You should notice a difference. If it still feels sloppy, then repeat the described procedure except adjust in 1/4 turn increments until you are happy. After each adjustment be sure to turn the wheel full left and right to be sure the steering gear does not bind.
Initially I adjusted mine too tight even though I had no binding. When I drove it I fought it all the time. I was constantly moving the steering wheel and that is a PITA. I adjusted the allen bolt CCW until I was happy. All steering boxes need a little slop or you will fight it as I did.
DSMMH
SpeedThrills
11-29-2016 10:30 AM
WidowMaker13
04-08-2015 11:22 AM
351Cleveland C4
1999 to 2016 Super Duty
12-18-2014 08:06 PM
BrandonLamb
05-12-2014 07:41 PM
GeneStoner
05-15-2003 02:22 PM
Quick Reply: 2002 Steering Problems
