Competition Diesel racing, sleds, dynos, power tuning and max performance.
Stock clutch and HP
Old 09-27-2007, 10:39 AM
brickie's Avatar
brickie
brickie is offline
Stock clutch and HP
How much can the stock clutch handle.I dont launch the truck just drive it often with max payload.Will it hold up to 500HP?
Old 10-15-2007, 08:34 PM
amish77's Avatar
amish77
amish77 is offline
Dunno, what's your engine/tranny setup. If it's lighter duty like a 302 or a 300 then definitely no. The real question here is not HP, but torque. Without engine/tranny numbers I couldn't tell you either way though.
Old 10-17-2007, 10:14 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
well, if it's a powerstroke with a stock dual mass flywheel, then i would go ahead and change it out now to a single mass flywheel and clutch. then your clutch will hold to about 300hp. that is about all the stockers can hold up to. if you want a clutch to hold 500hp call Dan Vallance at Valair clutch and he can set you up with a clutch for that.
Old 10-18-2007, 06:49 AM
brickie's Avatar
brickie
brickie is offline
Thanks Guys It is a 6.0 mated to the zf 6 speed.
Old 10-18-2007, 05:48 PM
amish77's Avatar
amish77
amish77 is offline
Yeah I'm thinking around 300 Hp, which should be about 500 to 600 Ft. Lbs of torque. That's about max. Makes you think about those tuners in a new way.
Old 11-08-2007, 01:38 PM
stang8893's Avatar
stang8893
stang8893 is offline
I have a 7.3 and it would hold an extra 75 HP put that was about it.
Old 05-24-2008, 04:30 PM
mitchrock1's Avatar
mitchrock1
mitchrock1 is offline
The stock clutch will not hold 500 hp. You need to upgrade once you get past the 80hp tune.
Old 05-24-2008, 07:41 PM
brickie's Avatar
brickie
brickie is offline
Oh yea I forgot about this thread.I put a south bend fb-8 in and am very happy with it. Its a little grabby and takes some getting used to but hooks up without slippage every time.
stuart olson
08-01-2017 12:35 PM
abowman
03-08-2017 12:12 PM
RhinoRidener7
06-08-2016 01:11 PM
GDSchafer
23
08-24-2015 09:45 AM
kenvs
1999 to 2016 Super Duty
10-24-2001 09:01 AM
Quick Reply: Stock clutch and HP
