front end vibration
#33
Originally Posted by arkredneck
haven't had a chance to check the truck yet but i did noticed that the vibration gets really bad at 80
He swapped the tires front to back..... I think something is loose. Bad alignment does not cause vibrations, but can make it worse. Same with shocks. So if it's not a wheel or tire, it has to be something loose. Could even be a driveshaft if you can't find anything loose in the front end.
#35
Tie Rod Ends
Have 99 F250 2wd. Barely made it home last night. Checked this afternoon and believe Tie Rods? Hooks to Passenger side brake assembly. Have about 180,000. Have changed shocks awhile back. Any body know where to find instructions on what to do to change Tie Rods? Do I need to do both sides? Then align? Any help appreciated as always> Dave
#36
#37
#38
#39
#40
you dont really need this but it would be good to have for the price for the "next odd job"
http://www.harborfreight.com/cpi/cta...emnumber=46389
Jerrod
11-25-2005 10:43 AM
