idle up, idle down, idle all around
Old 09-21-2007, 09:30 PM
handsomerob's Avatar
handsomerob
handsomerob is offline
O.K. got another problem, my idle revs up and down, my computer shows no error codes, I did plugs, wires, distributor cap and rotor. whats something else it could be?
Old 09-21-2007, 10:07 PM
Moore558's Avatar
Moore558
Moore558 is offline
Possible vacuum leak?
Old 09-21-2007, 10:11 PM
handsomerob
I'll check into it, not to sure on the vacuum system but I'll see what I can do.
Old 09-21-2007, 11:18 PM
biga17133's Avatar
biga17133
biga17133 is offline
spray wd40 all around carb and hoses[vacum lines] while engine running if it speeds up u have a vac leak,if it dont speed up not the problem....is it doing at idle or while running down the hwy..??
Old 09-22-2007, 06:40 AM
cowmilker's Avatar
cowmilker
cowmilker is offline
Idle Air Control Valve?
Old 09-22-2007, 08:07 AM
TheRoadVirus's Avatar
TheRoadVirus
TheRoadVirus is offline
I'm gonna go with cowmilker on this one. Same symptoms for me and it was IAC.
Old 09-22-2007, 11:03 AM
cowmilker's Avatar
cowmilker
I sold quite a few of those back when I worked at Checker Auto, they were problematic on almost all ford EFI's from the 1.8 Escort to the big V-8. If I remember right, they are about $50+ or -. Some one on this board mentioned taking it off and cleaning it with some kind of chemical, I don't remember what he said he used though. I do remember it was harsher then just carb spray (acetone maybe?).
Old 09-22-2007, 02:23 PM
TheRoadVirus
I'm gonna go back on what I said, lol. Ford told me that it was throwing a code for it and I didn't get around to replacing it until just now.. and it still fluctuates. Not nearly as bad so I'm thinking that it helped but not completely solved.
Old 09-22-2007, 04:31 PM
handsomerob
well, I checked the vacuum lines, there is a large black one that comes off the motor on the driver side (LH) and it splits one line then goes up by the maste cylinder and one goes to a reservoir, I checked and the line to the reservoir was clogged blew it out but didn't notica difference, the other issue is that there is no line comming out of the reservoir it's just capped off. is this normal? the reservoir is below the coolant overflow/wiper fluid tank.
Old 09-23-2007, 11:40 AM
handsomerob
bump bump
Old 09-23-2007, 11:46 AM
biga17133's Avatar
biga17133
HMMMMMMMM ,,,, take a picture there should not be anything under overflow washer reservior is it mounted to the firewall???
Feeling dum founded right now...lolol
Old 09-23-2007, 11:54 AM
DOHC330MustangGT's Avatar
DOHC330MustangGT
DOHC330MustangGT is offline
Check your TPS, too. Mine would go from a low idle to a rev and hang at like 2500 rpm's when it went bad - at random just sitting.
Old 09-23-2007, 12:21 PM
rkymtnman30's Avatar
rkymtnman30
rkymtnman30 is offline
This could be a vacuum problem at the EGRC/EGRV solenoid valves assembly I have been seeing a lot of these for some reason.
Old 09-23-2007, 01:36 PM
handsomerob
Old 09-23-2007, 05:03 PM
ducky17's Avatar
ducky17
ducky17 is offline
my truck did the same thing. I replaced the same things as you did and couldnt find any leaks.
a month or two later I had the battery unplugged for a little while and it fixxed the problem, just had to reset the computer I guess
Quick Reply: idle up, idle down, idle all around
