7.3 IDI heads on a 6.9
This may help you........
Cylinder head difference
Cylinder head bolts - 6.9 = 7/16"-14 UNC 5.25" long
Cylinder head bolts - 7.3 = 1/2" - 13 UNC 6" long
Cylinder head bolt washer 6.9 = .105" thick
Cylinder head bolt washer 7.3 = .134" thick
Head bolt torque -
6.9 with new bolts = 75ft. lbs.
6.9 with used bolts = 85ft. lbs.
7.3 new or used = 100ft. lbs.
Cylinder head gasket changes -
Fire ring I.D. 6.9 = 4.14"
Fire ring I.D. 7.3 = 4.22"
Gasket cutouts elimitated between cylinders on the 7.3 to eliminate cosmetic corrosion phenomenon.
Viton oil drain back sealing rings added to the 7.3 (also used in later versions of the 6.9 head gasket, then eliminated again).
Head design changes -
6.9 features "centered" glow plugs, while 7.3 are "off-center"
Injection nozzles have been retracted on the 7.3 .060" to facilitate Federal and state emission certs.
Precombustion chamber volume -
6.9 = 18.34 cm3
7.3 = 20.42 cm3 (increased only for emissions certs)
Precombusion chamber inserts are physically interchangable, however the throat has been redesigned to distinguish them apart, and the 7.3 prechamber cub has an embossed "88" on it.
Valve Stem -
The 7.3 valve stem oil sheild is larger to reduce hydrocarbon emissions. Intake and Exhaust sheilds have been color coded, even though they are identical and interchangeable.
Coolant passages -
The lower corner coolant passages on the cylinder head on the 7.3 have been plugged. This change is introduced to eliminate lower corner gasket coolant seepage during cold start engine warm-up. Mating passages in the block are also plugged. (could be why we hear more 7.3 overheating issues).
Exhaust valves - The 7.3 exhaust valve has had its alloy composition changed, with more nickel, chrome, and silver content, and decreased manganese content. The 7.3 valves may be used in the 6.9, but not the other way around.
Head bolt torque -
6.9 = 18.34 cm3
Valve Stem -
Coolant passages -
BahamasIDI
10-20-2013 04:13 PM
Diesel wyatt
10-13-2013 06:56 PM
Timf350
12-01-2012 07:43 PM
Brett1989
10-25-2008 10:24 PM
