HPOP plug?
HPOP plug?
I have an 05 6.0, recently I noticed it has been taking 3-4 seconds to crank. The night I was leaving to go offshore it took about 8-10 seconds to crank. I stopped to fuel up and again it to about 10 seconds to crank. It is running fine otherwise. From the research I have done here it seems like the HPOP. Might be as simple as the plug having a loose connection.
Well my truck is in Venice LA, which is past the end of civilization. When I get in in the morninig I am sure hoping it will crank up. Can anyone explain to me where the plug for the HPOP is so I can check if it is loose?
Or if anyone thinks it may be a different problem, please give me some input.
Thanks,
RaginCajun
Thanks,
RaginCajun
The HPOP, or high pressure oil pump, on the 05's was notorious for cracking/breaking a fitting inside the pump and causing a loss of oil pressure to the injectors, especially hot. It's not electrical. There is a newly designed fitting to repair it but will take a bit of work. It's covered under the 5yr/100K warranty w/$100 deductable.
RaginCajun,
It is on the top of the engine in the rear galley area below the turbo. You have to disassemble the top of the motor to get to it, so you will not be able to check it when you get off the boat. You need to take it to your favorite local 6.0 tech asap and get it diaganosed and fixed before it leaves you walking.
Here is a picture from the 6.0 Bible in the tech folder
http://dan.prxy.org/Truck/6L_bible_h...l/Page_04.html
I have worked on a few deep water jobs before. Right now I am on an inland barge rig Hercules 19. We are drilling for a small company, Dune Energy.
I live in Berwick. Thats right across the river from Morgan City.
I am a Mud Eng/Completion fluids Eng. What are you doing for Halliburton?
Thanks for the welcome.
Scott
Scott
frambin
59
06-15-2015 08:49 PM
rcorell
09-21-2014 06:20 PM
rcorell
09-21-2014 12:49 PM
duggyb
07-13-2014 04:30 PM
