Throttle body spacers
Old 09-07-2007, 03:34 AM
race21j's Avatar
race21j
race21j is offline
Hey everyone, do the 1 inch throttle body spacers do any thing? They claim more horsepower and some mileage gains.Don't want to throw money away.I want to put one on an 1989 F250 with a 351 .
Thanks
Old 09-07-2007, 06:13 AM
phil6608's Avatar
phil6608
phil6608 is offline
They make a very nice and expensive paperweight! lol Save your money for something that works!
Old 09-07-2007, 02:47 PM
race21j's Avatar
race21j
race21j is offline
Thanks that is what I thought,but I'm not real good with air flow on an EFI motor.The best thing I have put on so far is a K&N air filter.
Old 09-08-2007, 08:14 PM
ReAX's Avatar
ReAX
ReAX is offline
I have to agree, I was not happy with mine either. It made the intake whistle, I measured about 0.3 mpg decline and no extra power. If your running a stock intake, then perhaps they work, but I wouldn't do it with a cold air kit.
Old 09-08-2007, 09:29 PM
bareaneye's Avatar
bareaneye
bareaneye is offline
I had a very good experience with a throttle body spacer. I placed one on a 97 Yukon and gained about 1-1.5 mpg. When I put a FIPK from K & N on it, I lost!!! The throttle body spacer was the only bolt on that actually performed. I used the helix spiral type.
Old 09-08-2007, 11:30 PM
ReAX's Avatar
ReAX
ReAX is offline
Well your mixing two concepts. The screw type air directors (poweraid, s&t, tornado, ect.) put a spin on the air to make it more turbulent so fuel mixes better. The cold air kits are supposed to push air in at greater velocities, so when you add an air director your countering the effect the cold air intake is trying to achieve.
Old 09-18-2007, 07:16 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
The swirl type work fine if you have a carb or TBI. There is no fuel to mix in the air until it enters the intake port on the port injected vehicle.
Old 10-02-2007, 11:46 AM
wendell borror's Avatar
wendell borror
wendell borror is offline
They show improvement on some applications, like the jeep inline motors, also seem to be a benifit on the new mustang gt's with the 3V 4.6. Did nothing on my 4.0 in my ranger, but did notice a difference on my jeep 2.5. AEM sends a tb spacer along with thier cai if there is a benifit. If you get thier cai and it doesn't have a spacer, then there was no benifit on the ole dyno.
Old 10-03-2007, 10:00 AM
keyul's Avatar
keyul
keyul is offline
i used a tb spacer along with my cold air intake and did notice a difference. after those two mods i had some under drive pulleys thrown on and after that the truck would get between 20-22 mpg on the highway going 65-70. they make one hell of a whisteling sound.
Old 10-16-2007, 09:41 AM
waboose's Avatar
waboose
waboose is offline
It depends on the application, had a spacer on my 89 4.3 gm motor and worked great, installed one on my 97 when I bought it and noticed nothing. I think you'll notice a little power power and milage gains with your 89 as it is a wet intake system, as opposed to the newer dry intake systems.
Old 10-16-2007, 03:02 PM
blue beast's Avatar
blue beast
blue beast is offline
Lengthing the intake increases the torque of the motor to some extent. If it is like a phenolic spacer and made of plastic or some type of heat resisting material, That gains could be more, mostly from keeping the intake cooler. Pair up a phenolic spacer on the upper to lower intakes and a TB spacer and add some torque, of course if you have 3" exhaust or duals it won't be noticeable. If you keep a longer thinner stock exhaust tubing and add the spacers you will feel a difference.
Old 11-15-2007, 12:58 PM
Bob07FX2's Avatar
Bob07FX2
Bob07FX2 is offline
Same here, I ran my truck for about 3 weeks with just the spacer and noticed about a 1 MPG gain. I then installed a air-intake system and noticed a 3 MPG gain. Dosen't sound like much but, after time it'll add up.
Bob07fx2
Old 11-17-2007, 06:52 AM
race21j's Avatar
race21j
race21j is offline
Where do you buy the spacers for the Ford intakes? My parts store looked at me like I had a spare head.
Old 11-17-2007, 10:53 AM
wendell borror
Airaid makes them for fords and AEM.
Old 11-17-2007, 06:07 PM
Bob07FX2's Avatar
Bob07FX2
Bob07FX2 is offline
You can find them all over the internet. The AirRaid spacer I have cost $90 and about 15 minutes to put on. You'll have to replace the standard throttle body bolts with the longer ones that come with the kit.
Quick Reply: Throttle body spacers
