Ohms for glow plugs and Fusible Link for 14gauge wire
Old 09-02-2007, 03:49 PM
baddarryl's Avatar
baddarryl
baddarryl is offline
What is the number for to indicate good glow plugs in ohms on a 91 7.3 IDI F250?
Also, how large of a fusible link can be placed on a 14g wire?
Thanks.
Old 09-02-2007, 05:22 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Fuse links are usually specified at 2 gauge sizes smaller than the circuit wiring.
Steve
Old 09-02-2007, 08:29 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
If the glowplug reads 1 ohm or less(pretty much a dead short to ground), then it's good.
Old 09-02-2007, 09:24 PM
baddarryl's Avatar
baddarryl
Steve
Let me clarify. The controller with no load on it is only drawing 1 amp. With a load (2 or more plugs conected) it draws well past my 50amp ammeter. That is why we think there is a short in the controller, but then the question came up, could it draw more? We had a melted fusable link and wanted to replace it with a 50 amp fuse and holder.
Funny thing is in the early am we tested it and it drew 40 amps that influenced our decision to do the 50 amp fuse. So when we got it rewired, as a test, we put a 30 amp fuse in and it blew immediately. That is when we re measured and it blew off the dial. Could it be that the controller draws more amps when the temperature rises? Or does it have a short? We did individual tests to make sure no plugs were shorting, just any 2 or more will make it short.
My next move is to double check the plugs (they are less than a year old, so we figured them to be good) and see what the normal amperage draw is for that controller. If it is plus 50 then it might be fine and not need replacement. I hope this clarifies what I am getting at. Thanks.
Coastal Kenny
New Member Introductions
07-09-2016 12:14 AM
BDRUSS
24
12-22-2010 01:47 PM
76 crew
1966 - 1977 Early Broncos
03-06-2008 09:54 PM
papadelogan
Electrical Systems/Wiring
01-03-2008 04:52 PM
huntharbor
16
05-01-2007 01:31 PM
Quick Reply: Ohms for glow plugs and Fusible Link for 14gauge wire
