Glow Plug Fusible Links
Have a 2000 F350 7.3L, Problem is the glow plug relay to the fusible links keep frying. I have checked the Ground terminals at the engine block and both are nice and tight. First set i replaced literally caught on fire. Just replace the GPR with one from Oreillys as the other one was partially melted. Using the 12Gauge fusible links from NAPA. Luckily it came in the 5 foot roll. Might need all of it before this is figured out. If anyone can help it would be greatly appreciated.
Yes i just replaced the glow plugs and i am getting the correct OHMs. Everytime i go to even place the new links on the starter solenoid it sparks, when i tried to take replace them with the batter terminals disconnected, once i connected the terminals back to the batteries, the wires melted and caught fire.
Okay went home last night spent about 3-4 hours going through the darn thing looking for something that would tip me off. Again replaced the GPR last night, replaced a randon 30 Watt Buss Fuse, and checked every wire going from the starter solenoid to the GPR, The Intake Air Heater and back to the Alternators. Bought new Motorcraft Plugs to replace the ones which are in there. Still cannot figure out why it is still sparking and catching fire everytime i place the main GPR fusible links to the starter solenoid. There are 2 other sets of fusible links connected to the starter solenoiod but neither of those are having any problems so that should isolate the short. But i dont know where else to look. If the glow plugs were bad on either side of the engine, would it cause this? Thanks for all your help guys, this has pretty well got me baffled.
Okay so I didnt mention this before, and i am not sure if this brings anything else into play, but i am running the dual alternator system (ambulance package) not sure if this could cause more headache to it.
I took the wires out of the sheaths last night and ran them all the way back to the GPR. Now i did find that the wires coming from the top alternator going around the GRP and the AIH were spliced together with that wire coming out to the solenoid with the fusible link. It was all originall ford wrap and seal.
So i will need to unhook the lead wire to the AIH then try the fusible links again, got it. i will try this and see what happens.
Again thanks for all the help. Well i will say one thing, all this is a great learning experience
Deluxe06,
Thanks for the diagram. As far as starting from tthe alternator back i did that last night. Took all the wires out and checked them for any signs of burns or scrapes. Everything was fine. I will check again tonight and post the results. Hopefully happy ones, but im not too optimistic at this point.
