Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Kentucky Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: CampSpringsJohn
  #1 (permalink)
Old 08-29-2007, 11:55 AM
lightstar lightstar is offline
Garage is empty, add now
lightstar is starting off with a positive reputation.
safety
I have a 351w with a c4 trans. truck starts in any gear..what do i do to fix
  #2 (permalink)
Old 08-31-2007, 09:16 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
You need to wire in a neutral safety switch. Some are on the side of the trans betwen the linkage and housing.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 09-02-2007, 10:31 AM
found the switch..3 wires hanging there ..witch wire to where. thank you
  #4 (permalink)
Old 09-06-2007, 09:34 PM
LxMan1's Avatar
I'll look thru my manual and see if it gives the color codes. Only 3 wires? I figured 4. 2 for the start circuit ans 2 for the back-up lights.
The easiest way is with an ohm meter. Pick one wire and check the other 2 while in park. If you have continuity between 2, then put the shifter in R or Drive. If you lose continuity, then these 2 are the neutral safety wires.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 09-08-2007, 09:55 PM
thank you..soon as weather cools a little I'll go out and check/fix.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
